Gets the value of a given attribute of the part set.
Gets the list of attributes that can be passed to poIPartSet GetAttribute.
Gets the list of IDs for the part sets that are children of a part set in the part hierarchy.
Gets the part set ID.
Gets the ID of the parent of a part set in the part hierarchy.
Gets the list of IDs for the part assemblies that belong to a part set in the part hierarchy.
Gets the part set visibility.
Sets the part set visibility.
ON THIS PAGE
ON THIS PAGE
