A generic ASCII reader is now available which allows you to bring custom results directly into HyperView. The AltairASCII format is useful for reading the results of any in-house or propriety codes which are saved in a generic format.
External resources can be registered in preference files, session files, or Templex files. If an external resource is registered in a program session, it is automatically registered in the session
file when the session is saved.
Note: The following APIs will be listed under poICrossSectionPlanar
class when using Intellisense or ListMethods, however these will not work at this time as
Cross Sections are read-only and cannot be created or edited.
