Gets the average at node state.
Gets the use corner data state.
Gets the data component of this result definition.
Gets the data type of the result definition.
Gets the tensor format.
Gets the ID of the tensor definition.
Gets the label of the result definition.
Gets the layer of the result definition.
Gets the layer filter of the result definition.
Gets the loaded status of the result definition.
Gets the projection axis information.
Gets the result system of the result definition.
Gets the poISelectionSet handle of the result definition.
Gets the size of the selection set for a result definition for the specified model.
Gets the show midside node results state.
Gets the type of the result definition.
Sets the average at node state.
Sets the use corner data state for a result definition.
Sets the data component of the result definition.
Sets the data type of the result definition.
Sets the tensor format.
Sets the label of the result definition.
Sets the layer of the result definition.
Sets the layer filter of the result definition.
Sets the projection axis information.
Sets the result system of the result definition.
Sets the selection set which defines the entities of this result definition.
Sets the show midside node results state.
ON THIS PAGE
ON THIS PAGE
