API, Reference Guides
2023
  1. Home
  2. API, Reference Guides
  3. Tcl/Tk Commands
  4. Tcl/Tk Commands
  5. HyperView
  6. poIResultCtrl Class
  • What's New
  • Get Started
  • Tutorials
  • API, Reference Guides
Index
2023
  • What's New
  • Get Started
  • Tutorials
    • Extensions
    • External Readers and Altair Binary Format
    • Generic ASCII Reader
    • Batch Mode
    • External Resources
    • Tcl/Tk Commands
      • Program with APIs for Beginners
      • Object Hierarchy
      • Tcl/Tk Classes
      • Script Use Cases
      • Tcl/Tk Example
      • Program with Tcl/Tk Command Tutorials
      • Tcl/Tk Commands
        • Framework
        • MotionView
        • HyperView
          • Hotspot Finder API Structure
          • HyperView - MultiCore APIs
          • poI3DViewCtrl Class
          • poIAdvancedQuery Class
          • poIAssembly Class
          • poIBestView Class
          • poICFD Class
          • poICFD_rake Class
          • poICollisionCtrl Class
          • poICollisionSet Class
          • poIComplexCtrl Class
          • poIComponent Class
          • poIContourCtrl Class
          • poICrossSectionPlanar Class
          • poICrossSectionSet Class
          • poIExplosion Class
          • poIFBDCtrl Class
          • poIFLDCtrl Class
          • poIGraphicMaterial Class
          • poIImagePlaneCtrl Class
          • poIImagePlane Class
          • poIIsoValueCtrl Class
          • poILayerFilter Class
          • poILegend Class
          • poIMeasure Class
          • poIModel Class
          • poINote Class
          • poIPart Class
          • poIPartAssembly Class
          • poIPartSet Class
          • poIPost Class
          • poIPostManager Class
          • poIQueryCtrl Class
          • poIQueryDistanceRule Class
          • poIQueryExpressionRule Class
          • poIQueryExtremeRule Class
          • poIQueryIgnoreElemTypeRule Class
          • poIQueryIterator Class
          • poIQueryRule Class
          • poIQuerySetRule Class
          • poIRenderOptions Class
          • poIResultCtrl Class
            • poIResultCtrl AddSubcase
              Adds a derived subcase to a result.
            • poIResultCtrl AppendSimulation
              Adds a simulation reference to the current subcase.
            • poIResultCtrl CacheResult
              Adds the currently plotted result to the internal cache.
            • poIResultCtrl CancelLoading
              Cancels all loading associated with this result control.
            • poIResultCtrl CancelResult
              Cancels any pending tasks associated with a result definition.
            • poIResultCtrl ClearPlot
              Clears the plot of the specified result definition.
            • poIResultCtrl ClearResult
              Removes the specified result from the internal cache.
            • poIResultCtrl CreateLayerFilter
              Creates a layer filter.
            • poIResultCtrl EraseSubcase
              Erases a derived subcase from a result.
            • poIResultCtrl GetActiveIsoID
              Gets the result definition ID of the current iso plot.
            • poIResultCtrl GetActiveResult
              Gets the ID of the currently plotted result definition of the specified type.
            • poIResultCtrl GetCachedDataTypeList
              Gets a list of the ID-Name pairs for all of the cached data types.
            • poIResultCtrl GetCollisionCtrlHandle
              Gets a handle to the collision control object.
            • poIResultCtrl GetComplexCtrlHandle
              Gets a handle to the complex control object.
            • poIResultCtrl GetContourCtrlHandle
              Gets a handle to the contour control.
            • poIResultCtrl GetCurrentSimulation
              Gets the index of the current transient simulation.
            • poIResultCtrl GetCurrentSubcase
              Gets the current subcase ID.
            • poIResultCtrl GetDataComponentComplexFilter
              Returns whether or not a data component can be used with various complex filters for the specified subcase and data type.
            • poIResultCtrl GetDataComponentList
              Gets a list of all data components from the result file for the specified subcase and data type.
            • poIResultCtrl GetDataComponentTransformable
              Returns true if the component/derived type for the specified result allows system transformations.
            • poIResultCtrl GetDataDimensionList
              Gets the list of dimensions with non-empty datasets. Values include: node, line, shell, or solid.
            • poIResultCtrl GetDataTypeBinding
              Gets the binding for specified datatype return. Values include: node, element, or node_on_element.
            • poIResultCtrl GetDataTypeFormat
              Gets the format for specified datatype return. Values include scalar, vector, and tensor.
            • poIResultCtrl GetDataTypeList
              Gets a list with all data type labels from the result file for the specified subcase.
            • poIResultCtrl GetDisplaySelectionHandle
              Gets the display selection set handle. Note that this is only supported in async HyperView.
            • poIResultCtrl GetFLDCtrlHandle
              Gets a handle to the FLD control object.
            • poIResultCtrl GetDataTypePoolList
              Gets a list of pools.
            • poIResultCtrl GetIsoValueCtrlHandle
              Gets a handle to the iso value control object.
            • poIResultCtrl GetLayerFilterHandle
              Gets the handle for a layer filter.
            • poIResultCtrl GetLayerFilterList
            • poIResultCtrl GetLayerList
              Gets a list of shell layer labels from the result file for the specified subcase and data type.
            • poIResultCtrl GetNumberOfDataComponents
              Gets the number of data components for the specified subcase and data type.
            • poIResultCtrl GetNumberOfDataTypes
              Gets the number of data types in the result file for the specified subcase ID.
            • poIResultCtrl GetNumberOfShellLayers
              Gets the number of shell layers for the specified subcase and datatype.
            • poIResultCtrl GetNumberOfSimulations
              Gets the number of simulations for the specified subcase.
            • poIResultCtrl GetNumberOfSubcases
              Gets the number of subcases in the result file.
            • poIResultCtrl GetScaleCtrlHandle
              Gets a handle to the scale control object.
            • poIResultCtrl GetShellLayerList
            • poIResultCtrl GetSimulationLabel
              Gets the simulation label.
            • poIResultCtrl GetSimulationList
              Gets the list of simulation labels.
            • poIResultCtrl GetSimulationLoaded
              Query whether the given simulation step is loaded.
            • poIResultCtrl GetSubcaseLabel
              Gets the label of a given subcase.
            • poIResultCtrl GetSubcaseList
              Gets the list of subcase IDs in the result file.
            • poIResultCtrl GetSubcaseType
              Gets a label of a given subcase.
            • poIResultCtrl GetTensorCtrlHandle
              Gets a handle to the tensor control object.
            • poIResultCtrl GetVectorCtrlHandle
              Gets a handle to the vector control object.
            • poIResultCtrl IsLayerFilterValid
              Checks if the layer filter is valid for the given data type.
            • poIResultCtrl IsTrackable
              Utility function to find out the trackability of the specified data type.
            • poIResultCtrl LoadResult
              Loads data for the specified result definition.
            • poIResultCtrl LoadSimulation
              Loads position data (animation) for the given subcase and frame (index).
            • poIResultCtrl PlotResult
              Plots the specified result definition.
            • poIResultCtrl RemoveLayerFilter
              Removes the layer filter with the given ID.
            • poIResultCtrl RemoveSimulation
              Removes the simulation reference from the current subcase.
            • poIResultCtrl RestoreCachedPlot
              Restores the cached plot from the internal cache.
            • poIResultCtrl SetCurrentSimulation
              Sets the current transient simulation.
            • poIResultCtrl SetCurrentSubcase
              Sets the current subcase for result manipulation operations (for example: animation, contour, and vector plot).
            • poIResultCtrl SetDisplaySelectionSet
              Assigns a selection set for a given context on the result ctrl handle to display the plot on entities in the set. Note that this is only supported in async HyperView.
            • poIResultCtrl SetSubcaseLabel
              Sets the label of a derived subcase.
            • poIResultCtrl UnloadResult
              Clears and unloads data for the specified result definition.
            • poIResultCtrl UpdateResult
              Updates a result definition based on newly loaded steps.
            • poIResultCtrl UnloadSimulation
              Frees memory associated with the given simulation index.
          • poIResultMathCtrl Class
          • poIScalarDefine Class
          • poIScaleCtrl Class
          • poISCL Class
          • poISection Class
          • poISelectionSet Class
          • poIStressLinearizationCtrl Class
          • poISubcase Class
          • poISweepCtrl Class
          • poISymmetry Class
          • poISystem Class
          • poISystemCtrl Class
          • poITensorCtrl Class
          • poITensorDefine Class
          • poITextAttribute Class
          • poITracingCtrl Class
          • poITrackingSystem Class
          • poIVectorCtrl Class
          • poIVectorDefine Class
        • HyperGraph 2D
        • HyperGraph 3D
        • MediaView
        • TextView
        • HgTrans
        • TableView
        • Postquery Commands
        • Context Commands
        • Framework Commands
    • Translators
    • Result Math
    • HWC Console
    • HyperMesh Report
    • HyperMesh
    • MotionView
    • Templex and Math Reference Guide
    • Script and Model Library
2023
  1. Home
  3. Tcl/Tk Commands
  4. Tcl/Tk Commands
  5. HyperView
  • What's New
  • Get Started
  • Tutorials
Index
poIResultCtrl Class
Note: See the Animate and Visualize Results topic in the HyperView User's Guide for additional information.
