A generic ASCII reader is now available which allows you to bring custom results directly into HyperView. The AltairASCII format is useful for reading the results of any in-house or propriety codes which are saved in a generic format.
External resources can be registered in preference files, session files, or Templex files. If an external resource is registered in a program session, it is automatically registered in the session
file when the session is saved.
poIPostManager AddGraphicMaterial
Adds a material that describes the graphical properties of a surface, such as shininess, emmissivity, and specular color.
poIPostManager AddModel
Loads the given model file. A reference to the model needs to be attached to a post client window using AddModelReference.
poIPostManager GetAsyncMode
Query whether the HyperView - MultiCore (previously known as Upfront Data Loading Mode) is enabled or not.
poIPostManager GetResultReaderList
Gets a list of result readers for a given result file. If no filename is given, then all result readers are returned.
poIPostManager RemoveModel
Removes the given model from the master model table. The model is only removed if there are no other references to that model.
