A generic ASCII reader is now available which allows you to bring custom results directly into HyperView. The AltairASCII format is useful for reading the results of any in-house or propriety codes which are saved in a generic format.
External resources can be registered in preference files, session files, or Templex files. If an external resource is registered in a program session, it is automatically registered in the session
file when the session is saved.
When nodal results are in use, multiple results may exist for nodes along part boundaries. In these cases, the returned
list will contain the first nodal value encountered, while the nodal values for the other parts will be omitted.
poIVectorCtrl GetValueList
When nodal results are in use, multiple results may exist for nodes along part boundaries. In these cases, the returned list will contain the first nodal value encountered, while the nodal values for the other parts will be omitted.
