A generic ASCII reader is now available which allows you to bring custom results directly into HyperView. The AltairASCII format is useful for reading the results of any in-house or propriety codes which are saved in a generic format.
External resources can be registered in preference files, session files, or Templex files. If an external resource is registered in a program session, it is automatically registered in the session
file when the session is saved.
poIScalarDefine SetAverageFactor
Sets the nodal variation factor. Specify the threshold variation level above which nodal averaging should not be carried out.
