A generic ASCII reader is now available which allows you to bring custom results directly into HyperView. The AltairASCII format is useful for reading the results of any in-house or propriety codes which are saved in a generic format.
External resources can be registered in preference files, session files, or Templex files. If an external resource is registered in a program session, it is automatically registered in the session
file when the session is saved.
Gets the search tolerance for the target color that will be made transparent when the ColorAlpha image post-processing filter is active on the image plane.
Sets the search tolerance for the target color that will be made transparent when the ColorAlpha image post-processing filter is active on the image plane.
poIImagePlane GetAlignmentData
Gets a specific point or the list of points that were used (or would be used) to achieve a multipoint alignment for a 2D image plane.
poIImagePlane GetColorAlphaTarget
Gets the color that will be made transparent when the ColorAlpha image post-processing filter is active on the image plane.
poIImagePlane GetColorAlphaTolerance
poIImagePlane SetColorAlphaTolerance
