Adds a new image plane.
Gets the handle for the image plane.
Gets the unique ID for the image plane having the label specified.
Gets a list of image plane IDs.
Returns the order in which image planes are drawn when they are configured as background or foreground 2D image planes.
Alters the drawing order of a foreground or background image plane so that it is behind one (or more) other image planes.
Alters the drawing order of a foreground or background image plane so that it is in front of one (or more) other image planes.
Removes the specified image plane.
Sets the order in which image planes are drawn when they are configured as background or foreground 2D image planes.
ON THIS PAGE
ON THIS PAGE
