pltIPlot CutCurve
Cuts the curve and places it on the internal clipboard.
pltIPlot_handle CutCurve index, append
Tcl Modify
index
The number of the curve.
append
0
Appends the curve to other copied curves in the clipboard.
1
Replaces the contents of the clipboard with the curve.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName [myProjectName GetActivePage]
myPageName GetWindowHandle myWindowName [myPageName GetActiveWindow]
myWindowName GetClientHandle myPlotName
myPlotName CutCurve 1 0
myPlotName PasteCurve 0
Returns success or an error code.
