pltIPlot GetComplexTopArea
Finds the type of complex plot that is in the top area.
pltIPlot_handle GetComplexTopArea
Tcl Query
This command finds the type of plot that is in the top area of the complex plot.
real
imaginary
phase
magnitude
Note: This method is only valid for complex plots.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot GetComplexTopArea;
Success (one of the types of plot) or an error message is returned.
Keywords
Tcl
Complex Plot
Query
