pltIPlot CutRadialDatum
Cuts a radial datum.
pltIPlot_handle CutRadicalDatum datum, append_future
Tcl Modify
This command cuts a radical datum based on the user-input datum index. A radical datum is a line that goes around the plot in the polar plot (resembles a circle in the plot). It is used for comparison.
datum
The datum index (position in the datum list) that you want to cut.
append_future
true
Indicates the cut is added to a memory.
false
Indicates that the cut is not added to memory. This way, multiple cuts can be made and pasted at the same time, rather than cutting and pasting each one individually.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot CutRadicalDatum 1 true;
Keywords
Tcl
Polar Plot
Datum
Modify
