pltIPlot GetUniformAspectRatio
Indicates if the plot is using a uniform aspect ratio.
pltIPlot_handle GetUniformAspectRatio
Tcl Query
Returns true or false.
To determine if the current plot is drawn with a uniform aspect ratio (i.e., equal width and height):
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWindowName 1
myWindowName GetClientHandle myPlotName
myPlotName GetUniformAspectRatio
None.
