pltIPlot SetTipToTailSelectionMethod
Sets the selection method for the tip-to-tail curve.
pltIPlot_ctrl SetTipToTailSelectionMethod method
HyperGraph Polar Plot/Tip to Tail functionality.
This command sets the selection method for the calculation and drawing of the tip-to-tail curve.
method
Options include
“none”
None of the vectors is selected. Manual selection is not allowed.
“all”
All vectors are selected. Manual selection is not allowed.
“displayed”
Based only on the displayed vectors, you can select vectors manually.
“selected”
Based on all vectors of the plot, you make selections.
This command is only valid for polar plots, vector mode.
None of the vectors is included in the calculation and drawing of tip-to-tail curve. Tip-to-tail curve is off.
pltIPlot_Ctrl SetTipToTailSelectionMethod none
All vectors are included in the calculation and drawing of tip-to-tail curve.
pltIPlot_Ctrl SetTipToTailSelectionMethod all
You can manually select from the list which vectors should be included in the calculation and drawing of tip-to-tail curve.
pltIPlot_Ctrl SetTipToTailSelectionMethod selected
Returns an error code for invalid arguments.
