pltIPlot PasteNotes
Pastes previously copied or cut notes.
pltIPlot_handle PasteNotes index
Tcl Modify
This command pastes previously copied or cut notes into the notes list.
index
The index (position number) where you want to insert notes. PasteNotes pastes the user-input index and moves the list down one position if it is at or below that index (as to make room for the paste).
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot PasteNotes 3;
Keywords
Tcl
Note
Modify
