pltIPlot SetPhaseConstrain
Indicates whether the phase component should be constrained to the -180 to 180 range.
pltIPlot_handle SetPhaseConstrain on
Tcl Modify
This method is only valid for complex plots.
- on
- True or false.
Returns success or an error code.
