pltIPlot PasteHorizontalAxes
Pastes previously copied or cut horizontal axes.
pltIPlot_handle PasteHorizontalAxes index
Tcl Modify
This command pastes previously copied or cut axes into the axes list.
index
The index (position number) where you want to insert the axes. PasteHorizontalAxes pastes the user-input index and moves the list down one position if it is at or below that index
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot PasteHorizontalAxes 3;
Keywords
Tcl
XY plot
Modify
