Sketch Plane
Select a sketch tool, then select a sketch plane to begin sketching.
A sketch plane can be a global plane, a user-created reference plane, or a planar face of an existing part.
Learn about sketching basics including the sketch plane, legend, constraints, context menu options, and construction geometry.
The Sketch Legend in the upper left corner of the modeling window indicates whether a sketch entity is Projected or Intersected, and whether a sketch curve is Underdefined, Fully Defined, or Overconstrained.
Apply geometric relationships such as tangency and perpendicularity to sketch curves.
Create a sketch imprint, remove constraints, align axes, convert sketches to construction geometry, and show or hide grids, points, constraints, construction lines, dimensions, or intersection curves.
Construction geometry is used as a reference to line up or define other geometry.
All sketch data and parameter entities are handled according to the current unit system. All dimension values, variable manager values, and sketch entity data like line length, circle radius, or point position are appended with the current units system.
Create and assign variables to parameters when modeling.
Start a new sketch and select a sketch plane.
Project selected geometry onto the sketch plane as construction geometry.
Extract curves resulting from the intersection of the sketch plane with selected parts.
Sketch and edit a point, line, polyline, or line-arc.
Sketch and edit a rectangle.
Sketch and edit a parallelogram or a regular polygon.
Sketch and edit a circle.
Sketch and edit an ellipse or an elliptical arc.
Sketch and edit an arc.
Sketch and edit a spline.
Use the Dimension tool to define and/or constrain the dimensions of a sketch.
Trim or split a sketch curve.
Extend or shorten an entity of a sketch curve.
Round the corners of 2D sketch curves to create fillets with the same radius or different radii.
Offset or mirror a sketch curve.
Create a linear or circular pattern of sketch entities.
ON THIS PAGE
ON THIS PAGE
