bolt (washer 1 alt) LINK10
Creates CERIG element for the head and LINK10 element for body.
Use the Connector Browser to view and modify connectors in the current model.
Use the Control Manager to create and edit the various types of controls that will be used later when realizing connectors.
Use the tools in the Create tool set to create connectors, assign controls, and realize.
Create a dummy connector entity to add mass to a part, or create areas of mass to represent parts not present in the CAD or FE data.
Use the Quality controller to perform various checks on connectors and realized FE.
Use the FE Absorb tools to create connectors from existing mesh that meet specific types of realizations.
View details for different types of realizations.
A list of realization types that can be specified for point connectors.
A list of realization types that can be specified for fastener connectors.
Creates a RBODY per part with the center nodes connected to the SPRING2N element.
Creates a body with element type ‘Beam44’ element.
Creates RBE2 elements for the head and CBAR element for the body.
Creates a body with element type ‘Link10’ element.
Creates KINCOUP elements for the head and B31 element for the body.
This realization creates a single RBE2 element for the body.
Creates an RBODY elements and a zero length SPRING2N element.
The bolt (metal clip) creates elements, systems, and configurable body elements that connect a clip location.
Connects two solids through holes, or connects one solid through a hole with a solid blind hole.
Creates RBE2 (Nastran/OptiStruct) or KINCOUP (Abaqus) elements for the head and body.
Creates CERIG elements for the head and BEAM44 element for the body.
Creates CERIG element for the head and LINK10 for body.
Creates RBE2 (Nastran/OptiStruct) or KINCOUP (Abaqus) elements for the head and CBAR (Nastran/OptiStruct) or B31 (Abaqus) element for the body.
Creates RBE2 (Nastran/OptiStruct) or KINCOUP (Abaqus) elements for the head and the body.
Creates CERIG elements for the head and the LINK10 element for body.
Creates a single RBE2 element for the body.
Creates a ConNode rigidlink element for the body.
This realization creates a single ConNode rigidlink element (LS-DYNA) or RBE2 (Radioss) for the body, and projects and connects to nodes of the adjoining shell/solid within the prescribed cylinder diameter, L1 (cylinder height along the vector from the connector location) and L2 (cylinder height in the opposite direction of the vector from the connector location).
Creates a RgdBody rigidlink element for the body.
This realization creates RBE2 elements for the body, and projects and connects to the hole edge nodes with RBE3 elements.
A list of realization types that can be specified for line connectors.
A list of realization types that can be specified for area connectors.
Organize elements into connector groups.
The FE configuration file (feconfig.cfg) is used to define custom welds such as ACM (Area Contact Method) and other special types.
Attachments are an entity to facilitate the ease of joining subsystems.
Use the Connector tools to further define connections between components.
Abstract information incoming from the CAD hierarchy to robustly create connectors.
