HyperWorks
HyperWorks
2023
  1. Home
  2. Connectors
  3. Realizations
    View details for different types of realizations.
  4. Point Connector Realization Types
    A list of realization types that can be specified for point connectors.
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Meshing and Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • PhysicsAI
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
  • Collaboration Tools
Index
HyperWorks
2023
HyperWorks
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
    • Connector Browser
      Use the Connector Browser to view and modify connectors in the current model.
    • Define Connector Controls
      Use the Control Manager to create and edit the various types of controls that will be used later when realizing connectors.
    • Create and Realize Connectors
      Use the tools in the Create tool set to create connectors, assign controls, and realize.
    • Apply Mass
      Create a dummy connector entity to add mass to a part, or create areas of mass to represent parts not present in the CAD or FE data.
    • Check Connector Quality
      Use the Quality controller to perform various checks on connectors and realized FE.
    • FE Absorb Connectors
      Use the FE Absorb tools to create connectors from existing mesh that meet specific types of realizations.
    • Realizations
      • Point Connector Realization Types
        • acm (detached-(T1+T2)/2)
        • acm (equivalenced-(T1+T2)/2)
        • acm (general)
        • acm (shell gap + coating)
        • acm (shell gap contact + coating)
        • acm (shell gap)
        • bush
        • cbush (rigid)
        • cbush (spot tie)
        • cfast_elem (GA-GB)
        • cfast_elem (GS)
        • cfast_prop (GA-GB)
        • cfast_prop (GS)
        • CGAP (G)
        • cweld (GA_GB ALIGN)
        • cweld (GA_GB ELEMID)
        • cweld (GA_GB ELPAT)
        • cweld (GA_GB GRIDID)
        • cweld (GA_GB PARTPAT)
        • cweld (GS ELEMID)
        • cweld (GS ELPLAT)
        • cweld (GS GRIDID)
        • cweld (GS PARTPAT)
        • fastener
        • fastener-nodes
        • FEMFAT
        • HC hexa spotweld
        • hexa (spot tie)
        • hexa nugget
        • HiLock
        • Mastic
        • mat100 (hexa)
        • mat100
        • mat196
        • penta (mig + B)
        • penta (mig + L)
        • penta (mig + T)
        • penta (mig)
        • pie (rigid spider)
        • plink (connector position)
        • plink (middle of the gap)
        • rbe3 (load transfer)
        • rbe3-celas1-rbe3
        • rigid (crbody)
        • rigidlnk (midnode)
        • rod (spot tie)
        • sealing
        • type2 (spring)
      • Fastener Connector Realization Types
        A list of realization types that can be specified for fastener connectors.
      • Line Connector Realization Types
        A list of realization types that can be specified for line connectors.
      • Area Connector Realization Types
        A list of realization types that can be specified for area connectors.
    • Element Organization
      Organize elements into connector groups.
    • FE Configuration File
      The FE configuration file (feconfig.cfg) is used to define custom welds such as ACM (Area Contact Method) and other special types.
    • Attachments and Connectors
      Attachments are an entity to facilitate the ease of joining subsystems.
    • Connector Tools
      Use the Connector tools to further define connections between components.
    • CAD Abstraction
      Abstract information incoming from the CAD hierarchy to robustly create connectors.
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
HyperWorks
HyperWorks
2023
  1. Home
  2. Connectors
  3. Realizations
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
  • acm (general)
  • acm (shell gap)
  • bush
  • cbush (rigid)
  • cbush (spot tie)
  • cfast_elem (GS)
  • cfast_prop (GS)
  • CGAP (G)
  • cweld (GS ELEMID)
  • cweld (GS ELPLAT)
  • cweld (GS GRIDID)
  • fastener
  • fastener-nodes
  • FEMFAT
  • HC hexa spotweld
  • hexa (spot tie)
  • hexa nugget
  • HiLock
  • Mastic
  • mat100 (hexa)
  • mat100
  • mat196
  • penta (mig + B)
  • penta (mig + L)
  • penta (mig + T)
  • penta (mig)
  • rbe3-celas1-rbe3
  • rigid (crbody)
  • rod (spot tie)
  • sealing
  • type2 (spring)
