ConNode (spider)
Creates a ConNode rigidlink element for the body.
Restriction: Only available in LS-DYNA.
It connects to the nearest node to the connector position and then projects to the nearest nodes on the adjoining elements of the connected components.
The dyna ConNode (spider) exists in exactly the same configuration with the following additional names:
  • HC cylinder rigid bolt
  • HC cylinder rigid clip
This is in order to keep the realization names from HyperCrash.
