Analysis
Analysis entities stores settings and entities for composite stress toolbox calculations.
In the composite stress toolbox, various analyses exist for which a combination of entities and/or additional settings are required. The analysis entity is a container for the necessary selections and allows for storing the analysis setups for easy re-run.
The items in the following table comprise analysis entity data.
| Option | Description |
| Name | Name of the analysis. |
| Type | Used to specify the analysis type.
| Entity | Entity or entities assigned to the analysis. Can be materials, plies, or laminates depending on analysis type. |
| Plate load | Collections of loads with type “Composite plate load” (load response only). |
| FPF settings | First_Ply_Failure design point method assigned to the analysis (strength and optionally load response). |
