Interface Component
Interface Component entities create an interface in interface file for use in subsequent linking calculations.
Each definition consists of a set of cards that define the interface. Interfaces may consist of a set of segments for later use with *INTERFACE_LINKING_SEGMENT, an ordered line of nodes for use with *INTERFACE_LINKING_EDGE, or an unordered set of nodes for use with *INTERFACE_LINKING_NODE.
LS-DYNA Cards
| Card | Description |
| *INTERFACE_COMPONENT (NODE & SEGMENT) | Creates an interface in interface file for use in subsequent linking calculations. |
