/MAT/PLAS_PREDEF
Block Format Keyword This material law has predefined elasto-plastic data for some common steel, aluminum, and plastic materials.
| /MAT/PLAS_PREDEF/mat_ID | |||||||||
| mat_title | |||||||||
| Material name | |||||||||
Definition
| mat_ID | Material
identifier. (Integer, maximum 10 digits) |
| mat_title | Material
title. (Character, maximum 100 characters) |
| Material name | Predefined material
name. 3
(Character, must be left-justified when entered) |
Example (Steel)
#RADIOSS STARTER
#- 2. MATERIALS:
/MAT/PLAS_PREDEF/1
Material for generic mild steel
STEEL
#ENDDATA
/END
- This material provides elasto-plastic material data that can be used early in a design when material data might not be available. The data is from the results of several publicly funded projects. The material model defines stress as a function of strain. No strain rate or temperature effects are included. Failure can be modeled by using the same predefined materials in /FAIL/BIQUAD.
- The material data is automatically converted into the model’s unit system defined in /BEGIN.
- This material uses
/MAT/LAW2 (PLAS_JOHNS), Iflag=1 with these predefined values in the units, kg, mm,
and ms.
Name Material Description Density E Yield Stress UTS STEEL Mild steel 7.8E-6 210 0.3 0.160 0.380 0.24 HSS HSS steel 7.8E-6 210 0.3 0.300 0.510 0.23 UHSS UHSS steel 7.8E-6 210 0.3 0.500 1.500 0.045 AA5182 Aluminum AA5182 2.7E-6 70 0.33 0.150 0.300 0.25 AA6082-T6 Aluminum AA6082-T6 2.7E-6 70 0.33 0.300 0.360 0.08 PA6GF30 Plastic PA6GF30 1.3E-6 7 0.35 0.050 0.100 0.02 PPT40 Plastic PP T40 1.2E-6 4 0.3 0.020 0.030 0.06
- E
- Young's modulus
- Poisson's ratio
- Yield Stress
- Material yield stress
- UTS
- Ultimate Tensile Stress (engineering stress)
- Engineering strain at UTS
