Review mechanics of connections with separating or closing contact
        conditions.
        This feature does not support bonding or sliding contact conditions. Four
                response types are available:
                    - Load condition: normal traction (contact pressure)
                    - Load condition: tangential traction
                    - Displacement Condition: contact opening (deformational gap)
                    - Displacement Condition: contact slippage
                On the Project Tree, open
                    the Analysis Workbench.
                In the workbench toolbar, click the
 (Contact Response) icon.
                In the Project Tree, select the connection you want to
                    view.
                Select a Response type in the drop-down menu.
                Use the slider to select Display point size.
The modeling window will update to display the
                    chosen results.
                Click Close.
