poIImagePlane GetMode
Gets the drawing mode for the image plane.
Imageplane_handle GetMode
HyperView Tcl Query
Image planes support three drawing modes: foreground, background, and 3D. In the foreground and background modes, the image or video is drawn as a flat rectangle, either in front of all the 3D model elements in the graphic area, or behind all the 3D model elements in the graphic area, respectively. In 3D mode, the image plane is drawn as a plane in three dimensional model space. It follows the rotation, zoom, and panning of the rest of the model, and can be also be aligned so that the camera angle of the image or video matches the 3D position of the plane relative to the FE model. This command returns which mode the image plane is in.
To create two image planes, and then query it for basic properties and settings:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetImagePlaneCtrlHandle ipc_handle
set ipid1 [ipc_handle AddImagePlane Logo1]
ipc_handle GetImagePlaneHandle imageplane_handle $ipid1
imageplane_handle SetFileName g:/samples2/VideoOverlay/logo1.jpg
imageplane_handle SetMode background
imageplane_handle ReleaseHandle
set ipid2 [ipc_handle AddImagePlane Video1]
ipc_handle GetImagePlaneHandle imageplane_handle $ipid2
imageplane_handle SetFileName g:/samples2/VideoOverlay/video1.jpg
puts "ImagePlane Basic Properties :";
puts "  ID =       [imageplane_handle GetID]";
puts "  Filename = [imageplane_handle GetFileName]";
puts "  Label =    [imageplane_handle GetLabel]";
puts "  Syncblock ID = [imageplane_handle GetSyncBlockID]";
puts "  Visibility = [imageplane_handle GetVisibility]";
puts "  Alpha =    [imageplane_handle GetAlpha]";
puts "  Mode  =    [imageplane_handle GetMode]";
puts "  Associated Model ID = [imageplane_handle GetAssociatedModelID]";
puts "  Cull Angle = [imageplane_handle GetCullAngle]";
puts "  Backface Visibility = [imageplane_handle GetBackFaceVisibility]";
puts "  Crop =     [imageplane_handle GetCrop]";
puts "  Stretch =  [imageplane_handle GetStretchToFit]";
puts "  Maintain Aspect =  [imageplane_handle GetMaintainAspectRatio]";
hwi CloseStack
Console Output:
  ID =       1
  Filename = g:/samples2/VideoOverlay/logo1.jpg
  Label =    Logo1
  Syncblock ID = W1:V1
  Visibility = true
  Alpha =    100
  Mode  =    Background
  Associated Model ID = -1
  Cull Angle = 20
  Backface Visibility = false
  Crop =     0.00, 0.00, 1.00, 1.00
  Stretch =  false
  Maintain Aspect =  true
None.
