poIPartSet GetPartAssemblyList
Gets the list of IDs for the part assemblies that belong to a part set in the part hierarchy.
poIPartSet_handle GetPartAssemblyList
HyperView Tcl Query
This command retrieves the list IDs for the part assemblies that belong to a part set in the part hierarchy. An empty list is returned if there are no part assemblies in the part set.
To get the part assembly IDs for part set 1:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetPartSetHandle part_set_handle 1
part_set_handle GetPartAssemblyList
hwi CloseStack
Returns HW_InvalidHandle (3) if the part set handle is invalid.
