poI3DViewCtrl GetInputSensorHeight
Gets the input sensor height of a stored view.
poI3DViewCtrl_handle GetInputSensorHeight name
HyperView Tcl Query
Returns a float number representing the input sensor height in mm. This value is typically the same as the manufacturer specifications of a camera lens.
name
If specified, the height of the view with that name will be returned. Otherwise, the current view’s height will be returned.
To get the input sensor height of a view named "View 1":
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetViewControlHandle view_handle
view_handle GetInputSensorHeight "View 1"
hwi CloseStack
Error
Returns HW_InvalidHandle if the view handle is invalid.
Returns HW_InvalidArgs if the named view does not exist.
