poICFD GetMaxBreakAngle
Returns the threshold value for the break angle between two neighboring streamline segments, which is used to decide if the two line segments should be merged into one, or kept untouched.
poICFD_handle GetMaxBreakAngle
HyperView Tcl Query
This command returns the threshold value for the break angle between two neighboring streamline segments, which is used to decide if the two line segments should be merged into one, or kept untouched.
Note: All decimation criterion will not take effect if streamline decimation is turned off.
To get the break angle threshold for streamline decimation:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetCFDCtrlHandle CFD_handle
CFD_handle GetStreamLineSize
hwi CloseStack
Error
This command always returns the current break angle threshold.
