poICFD_rake SetNumberOfSeeds
Specifies the number of the seeds in the rake used for the stream integration creation in the CFD Plot/Streamlines panel.
poICFD_rake_handle SetNumberOfSeeds num_seeds
HyperView Tcl Modify
- num_seeds
- The number of seeds in the rake.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetCFDCtrlHandle CFD_handle
CFD_handle GetRakeHandle CFD_rake_handle [CFD_handle AddRake "line"]
CFD_rake_handle SetNumberOfSeeds 20
hwi CloseStack
Error
Returns HW_InvalidArgs if the number of seeds specified is not a positive integer.
