poIFBDCtrl IsCrossSectionValid
Checks to see if the cross section is valid.
poIFBDCtrl_handle IsCrossSectionValid context
HyperView Tcl Query
This command is used to check to see if the cross section is valid.
- context
- The cross section ID.
Returns invalid if the cross section does not have any element sets defined.
