poILegend GetMaxByModel
Gets the legend maximum for a given model ID.
legend_handle GetMaxByModel modelID formatted
HyperView Tcl Query
This command retrieves the maximum legend value for a given model ID.
- modelID
- The model ID for which the legend maximum value is required.
- formatted
- The formatted output required or not. The default value is true.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetContourCtrlHandle contour_handle
contour_handle GetLegendHandle legend_handle
set maxValue [legend_handle GetMaxByModel 1]
hwi CloseStack
Returns a float value.
