poIPost AddMeasure
Creates a measure.
poIPost_handle AddMeasure type
HyperView Tcl Modify
This command creates a measure.
type
The type of the measure. If not specified, an undefined measure is created. Valid values are: Angle Between, Circle Radius, Distance Between, Elemental Contour, Incremental Angle, Incremental Distance, Minimum Distance, Nodal Contour, Node Path, Position, Relative Angle, Relative Displacement, and Yaw Pitch Roll.
Returns the newly created measure ID.
