poIQueryExtremeRule GetExtreme
Gets the query extreme rule type from the advanced query.
rule_handle GetExtreme
HyperView Tcl Query
This command is used to get the extreme query rule type from the advanced query.
To get the extreme query rule type from the advanced query:
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule extreme]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetExtreme "BottomN 4"
hwi CloseStack
This command returns HW_InvalidHandle, if the core object associated with the advanced query handle does not exist anymore.
