poISelectionSet GetVisibility
Retrieves the visibility setting of the current selection set.
selectionSet_handle GetVisibility
HyperView Tcl Query
This command returns the current setting for visibility on the selection set. The return value can either be false or true. If the current selection set is emphasized on the model, this command returns true. If it is not shown emphasized, it returns false.
To create a selection set containing all nodes, make it visible in the graphic area, and use GetVisibility to retrieve the visibility state on the current selection set:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle AddSelectionSet node
puts "Current selection sets: [model_handle GetSelectionSetList]\n"
model_handle GetSelectionSetHandle selection_set_handle 1
selection_set_handle SetLabel "OurNodeSelectionSet"
selection_set_handle Add all
puts "Current selection set ID: [selection_set_handle GetID]"
puts "   Label: [selection_set_handle GetLabel]"
puts "   Size:  [selection_set_handle GetSize] [selection_set_handle GetType]s"
puts "   Default color:      [selection_set_handle GetColor]"
puts "   Default visibility: [selection_set_handle GetVisibility]"
puts "----------------------"
selection_set_handle SetVisibility true
puts "   Current visibility: [selection_set_handle GetVisibility]"
hwi CloseStack
This command should always return the current visibility. If the selection set handle is not retrievable, this command returns false.
