poIStressLinearizationCtrl SetDatatype
Sets the data type to be used for Stress Linearization.
poIStressLinearizationCtrl_handle SetDatatype type
HyperView Tcl Modify
This command sets the data type to be used for Stress Linearization. The first stress data type found will be listed as the default.
- type
- The data type to be used.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_ctrl
result_ctrl GetStressLinearizationCtrlHandle stresslin_ctrl
stresslin_ctrl SetDatatype datatype
hwi CloseStack
None.
