poISubcase GetDataComponentTransformable
Returns whether or not the data component is transformable.
subcase_handle GetDataComponentTransformable datatype datacomp
HyperView Tcl Query
This command returns whether or not the data component is transformable (true or false).
- datatype
- The data type for the components which are requested.
- datacomp
- The label of the data component which is tested (whether it is transformable or not).
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetSubcaseHandle subcase_handle 1
set bool_transform [subcase_handle GetDataComponentTransformable stress xx];
hwi CloseStack
None.
