poISymmetry GetSelectionSetSize
Gets the set size of the symmetry controller.
sym_handle GetSelectionSetSize
HyperView Tcl Query
This command returns the number of parts contained in the selection set within the symmetry controller.
To get the selection set size of the symmetry controller:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetSymmetryCtrlHandle sym_handle
set num [sym_handle GetSelectionSetSize]
hwi CloseStack
Returns an empty string if an error occurs.
