poIVectorDefine SetDataComponent
Sets the data component of the result definition.
poIVectorDefine_handle SetDataComponent comp
HyperView Tcl Modify
This command, valid only in HyperView - MultiCore profile, sets the data component for the result definition. Returns Success (0) or an error code.
Note: The result definition can only be modified if it is not cached.
comp
The data component label (x, y or z):
To set the data component of a vector result definition to y:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetResultHandle vdefine 3 vector
vdefine SetDataComponent y
hwi CloseStack
Returns an error code if there was an error setting the data component and sets error condition on the session handle. See session_handle GetError.
See the HyperView - MultiCore APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
