Record Node Movements
Record node movements using other HyperMesh tools and save them as a shape.
Define morphing preferences.
Morph constraint entities restrict or prescribe the movement of nodes during morphing, with a variety of available methods and dimensional values. These constraints are valid across all available morphing approaches and can be individually activated or deactivated at any time, even in between morphs or applying shapes.
Use the Free tool to morph mesh by moving nodes, handles, or domains, by applying shapes, or by mapping to geometry.
Use the Proximity tool to morph mesh using a simple distance or perturbation value around selected nodes, faces, edges, or shapes.
Morph volume entities are highly deformable six-sided prisms which surround a portion of the FE mesh, and can be used to manipulate a mesh by manipulating the shape of the morph volume.
Shapes are collections of perturbations from the initial configuration of the FE mesh before the morph.
Create and apply morphing shapes. Shapes can be created by morphing or by converting load collectors.
Delete selected shapes.
Animate selected shapes.
Convert a shape to node perturbations, handle perturbations, an mvol shape, forces, temperatures, pressures, or displacements.
Use the Check/Smooth function to check the element quality of shape combinations and optionally smooth the shapes to improve the element quality when applied individually or as part of a combination of shapes.
Use the Autoshape function to automatically generate multiple shapes for individual handles or domains.
Import saved shapes from a file.
Export selected shapes.
The Move, Mirror, and Scale tools all support shapes as a valid entity type.
Morph a mesh by selecting a dimension in the model and change its values.
Domain entities divide the model into different domains during morphing.
Handle entities control the shape of domains during morphing.
Symmetry entities define planes of symmetry within a model so that morphs can be applied in a symmetric fashion.
Change the biasing factors associated with each handle.
Map nodes, domains, morph volume edges, or morph volume faces in your model to a line, node list, plane, surfaces, elements, or an equation using edge domains and handles to guide the process.
Mold a mesh with a variety of virtual tools, such as creating hemispherical divots, cone-shaped projections, or molding sections with feature lines.
Undo all morphs and return to the original state of the model.
