poICrossSectionPlanar SetThickness
Sets the thickness of the cross section lines.
poICrossSectionPlanar_handle SetThickness thickness
HyperView Tcl Modify
This command retrieves the thickness of the cross section edge lines. Only valid when running HyperView.
- thickness
- Thickness value from 1 - 6 or "global" to use the global section cut thickness as defined in the preferences.
Returns 0 if successful, otherwise an error code.
