poICrossSectionPlanar GetThickness
Gets the thickness of the cross section lines.
poICrossSectionPlanar_handle GetThickness
HyperView Tcl Query
This command retrieves the thickness of the cross section edge lines or "Global" if using the global section cut thickness as defined in the preferences. Only valid when using HyperView.
None.
