poIResultCtrl GetLayerFilterHandle
Gets the handle for a layer filter.
poIResultCtrl_handle GetLayerFilterHandle layer_filter_handle layer_filter_id
HyperView Tcl Query
This command returns the layer filter for a given layer filter ID. This handle can be further used to modify/update the layer filter.
- layer_filter_handle
- The layer filter handle.
- layer_filter_id
- The ID of the layer filter to which the handle is required.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle CreateLayerFilter 1 "Composite Stress" 2
result_handle GetLayerFilterHandle filter_handle 1
filter_handle AddLayer "Ply 1"
filter_handle AddLayer "Ply 10"
hwi CloseStack
Returns an error if the result controller handle is invalid, or if the layer filter with the given ID does not exist.
