poIResultCtrl GetDataTypeBinding
Gets the binding for specified datatype return. Values include: node, element, or node_on_element.
poIResultCtrl_handle GetDataTypeBinding subcase_id datatype
HyperView Tcl Query
This command retrieves the binding for specified datatype return. Values include: node, element, or node_on_element.
- subcase_id
 - Set to a positive integer.
 - The data type label.
Returns node, element, or node_on_element if the data type exists, or (null) otherwise.
