2022.2 API Programmer's Guide
Properties to Elementbehaviors
The LS-DYNA keywords *DEFINE_ELEMENT_DEATH and *DEFINE_ELEMENT_EROSION have been mapped from the property entity to the elementbehavior entity. See the elementbehaviors data names documentation for more details.
Scripts that created or queried the property entity for these keywords must be updated to use the elementbehavior entity.
*createentity elementbehaviors config=101
*createentity elementbehaviors config=102
*setvalue elementbehaviors id=1 STATUS=1 PERCENT=1.0
*setvalue elementbehaviors id=1 STATUS=1 NUMFIP=10.0
hm_getvalue elementbehaviors id=1 dataname=PERCENT
hm_getvalue elementbehaviors id=1 dataname=NUMFIP
Properties to Materialbehaviors
The LS-DYNA keywords *DEFINE_CONNECTION_PROPERTIES and *DEFINE_CONNECTION_PROPERTIES_ADD have been mapped from the property entity to the materialbehavior entity. See the materialbehaviors data names documentation for more details.
Scripts that created or queried the property entity for these keywords must be updated to use the materialbehavior entity.
*createentity materialbehaviors config=111
*createentity materialbehaviors config=111 ADD_option=1
*setvalue materialbehaviors id=1 STATUS=1 PRUL=1
*setvalue materialbehaviors id=1 STATUS=1 Number_of_Materials=2
hm_getvalue materialbehaviors id=1 dataname=PRUL
hm_getvalue materialbehaviors id=1 dataname=Number_of_Materials
New Commands
- Airbag Folding
- Connectors
- Data Names
- General/Core
- Geometry
- HMASCII
- Meshing
- Post-processing
- Subsystems
- Template Commands
- Template Functions
Modified Commands
- Subsystems
- *modent_addcontentsbyids – Only one includefile entity can be associated with a subsystem.
- *modent_addrepresentations – Added new value HyperMesh for representation_file_format.
- *modent_removecontentsbyids– Removing an includefile entity is not allowed when modular_entity_type is subsystem.
- *modent_saverepresentation – Subsystem representations are saved in a HyperMesh database.
- Data Names
- analysis - Added new loadtype values 114 and 115.
- analysisparameters - Added new data names disp, disp_select, dof, dof_select, grid and grid_select.
- beamsects - Added new data names center, computeproperties, partscount, partmanagertable, partmaterial, partname, and partsize.
- components - Added new data name explosion.
- includefiles - Added new data name is_managed.
- loads
- accelerations - Added new data names for Abaqus engineering loads: boundary_region, cyclic_mode, dload_type, matrix_generation, ref_node, ref_set, and rot_axis_pos.
- constraints - Added new data names for Abaqus engineering loads: boundary_region, firstdof, lastdof, load_case, and variable_type.
- fluxes - Added new data names for Abaqus engineering loads: boundary_region, firstdof, load_case, and variable_type.
- forces - Added new data names for Abaqus engineering loads: boundary_region, cyclic_mode, load_case, and matrix_generation.
- moments - Added data name for Abaqus engineering loads: boundary_region, cyclic_mode, dload_type, load_case, matrix_generation, and rot_axis_pos.
- pressures - Added new data names for Abaqus engineering loads: boundary_region, cyclic_mode, dload_type, dsload_type, matrix_generation, pipe_diameter, ref_node, and ref_set.
- temperatures - Added new data name for Abaqus engineering loads: boundary_region, firstdof, lastdof, load_case, and variable_type.
- materialbehaviors - Added new data names ADD_option, AREAEQ, CON_ID, DDGPR, DDGPR_Funct, DETAN, DETAN_Funct, DEXSB, DEXSB_Funct, DEXSN, DEXSN_Funct, DEXSS, DEXSS_Funct, DGFAD, DGFAD_Funct, DGPR, DGTYP, DLCSB, DLCSN, DLCSS, DRANK, DSB, DSB_Funct, DSCLMRR, DSIGY, DSIGY_Curve, DSIGY_Funct, DSN, DSN_Funct, DSS, DSS_Funct, ETAN, EXSB, EXSN, EXSS, GFAD, LCSB, LCSN, LCSS, MID_array, MOARFL, Number_of_Materials, OPT_DSIGY_curve, OPT_SIGY_curve, PRUL, RANK, SB, SCLMRR, SIGY, SIGY_Curve, SN, and SS. Added a new config value 111.
- retractors - Added new data names EL_ID, Elem_size, Fct_ID1, Fct_ID2, Fct_ID3, Force, Node_ID, Pullout, Sens_ID1, Sens_ID2, Tens_typ, Xscale1, Xscale2, Yscale1, Yscale2. Added new config value 201.
- seatbelts - Added new data names resolve_intersections, seg_intersection_resolve, and seg_intersection_elems.
- sliprings - Added new data names A, Ed_factor, EL_ID1, EL_ID2, EL_SET1, EL_SET2, Fct_ID1, Fct_ID2, Fct_ID3, Fct_ID4, Flow_flag, Fricd, Frics, Node_ID, Node_ID2, Node_SET, Sens_ID, Xscale1, Xscale2, Xscale3, Xscale4, Yscale2, Yscale4. Added new config values 201, 202.
- subsystems - Added new data names maxid and minid.
- tables - Added new data name dtablevalue.
- General/Core
- *absorbentities - Added support for properties.
- *absorbloads - Added groups as a possible value for entity_type.
- *elementchecksettings - Value 3 (LS-DYNA) is now supported for solver, aspect_2d, aspect_3d, angle, cell_squish_2d, chord_dev, skew_2d, skew_3d, skew_3d, taper, tetra_collapse, time_step, and warpage.
- *realizefieldloads - Added support for groups.
- *realizehmentity - Added support for solvermasses.
- *setoption/hm_getoption - Added new options auto_bs_thickness, br_autofit_graphics, br_autoscroll, br_autosort, br_filter_mode, br_filter_nested, br_partbrowser_show_components, br_show_entities_all, br_show_treelines, bs_thickness, cadupdate_inspire_installation, elem_sphere_radius, intell_exact_match, intell_max_id, intell_max_name, left_justify_num_fields, sketcher_shade_closed_regions, and sketcher_update_in_inspire.
- Geometry
- *autotopocleanuplimited - Added new optional argument adj_surfs_layers.
- Meshing
- *midmesh_extract - Added new options MidlineTrimFilletsFactor and SuppressProximityFilletsFactor.
- *update1delements - Added new sectiontype value solid and new options createsketch and mergetol.
Deprecated Commands
- *setgraphictranslation - Use *setvalue to set the explosion data name on a component entity.
Removed Commands
The following commands/options have been removed and are no longer available for use in scripts:
- General/Core
- *DeleteUC - Use *createmark and *deletemark instead.
- *setoption/hm_getoption - Removed the option partbrowser_with_components.
- *UpdateController - Use *setvalue instead.
