analysis
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
1 - Composite analysis
composite_panel_type
The type of composite analysis.
1 - Engineering constants
2 - Load response/first ply failure
3 - Strength
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
entitytype
The type of the entity to analyze.
entity
The ID of the entity to analyze.
Type: entity
fpfsettings
The ID of the design point method entity used as the first ply failure settings.
Type: entity
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
load
The ID of the load entity.
Type: entity
loadtype
The type of load entity used in the analysis.
6 - panel load
114 – result subcase
115 – result simulation
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
Version History
2021.2
2022.2 - Added new loadtype values 114 and 115.
