*deletemark
Deletes entities from the database.
*deletemark entity type mark
HyperMesh Tcl Modify Command
- entity type
- The type of entity contained on the mark.
- mark
- The ID of the mark to be deleted.
Examples
*createmark lines 1 12 13 14
*deletemark lines 1 This command cannot be used to delete nodes, unless they are temporary nodes that are not connected to any other HyperMesh entity.
