2022.3 API Programmer's Guide
Properties to Constraints
The LS-DYNA a *CONSTRAINED_JOINT_STIFFNESS_FLEXION-TORSION, *CONSTRAINED_JOINT_STIFFNESS_GENERALIZED, *CONSTRAINED_JOINT_STIFFNESS_TRANSLATIONAL and *CONSTRAINED_JOINT_STIFFNESS_CYLINDRICAL keywords have been mapped from the property entity to the constraint entity. See the constraints data names documentation for more details.
Scripts that created or queried the property entity for these keywords must be updated to use the constraint entity.
*createentity constraints config=102 Type=1*createentity constraints config=102 Type=2*createentity constraints config=102 Type=3*createentity constraints config=102 Type=4*setvalue constraints id=1 STATUS=1 ESAL=1.1
*setvalue constraints id=1 STATUS=1 EST=2.2
*setvalue constraints id=1 STATUS=1 ESX=3.3
*setvalue constraints id=1 STATUS=1 ESR=4.4hm_getvalue constraints id=1 dataname=ESAL
hm_getvalue constraints id=1 dataname=EST
hm_getvalue constraints id=1 dataname=ESX
hm_getvalue constraints id=1 dataname=ESRNew Commands
- Connectors
- Data Names
- General/Core
- Geometry
- HMASCII
- Meshing
- Morphing
- Multiple Models
- Skeleton
- Template Commands
Modified Commands
- *element_smooth_nodes - Added new option anchornodes.
- *elementqualitysplitelem - Updated the syntax to support name-value argument pairs and added new option swap.
- *splitelementbyelemselect - Updated the syntax to support name-value argument pairs and added new option consider1ds.
- Connectors
- hm_ce_getallfe - The returned list now contains the post created entities such as materials, properties, contacts, and so on.
- Data Names
- constraints - Added new data names CIDA, CIDB, DLCIDAL, DLCIDBT, DLCIDG, DLCIDP, DLCIDPH, DLCIDPS, DLCIDR, DLCIDT, DLCIDX, DLCIDY, DLCIDZ, ESAL, ESBT, ESPH, ESPS, ESR, EST, ESX, ESY, ESZ, FFR, FFR_CURVE, FFR_CURVE_OPT, FFX, FFX_CURVE, FFX_CURVE_OPT, FFY, FFY_CURVE, FFY_CURVE_OPT, FFZ, FFZ_CURVE, FFZ_CURVE_OPT, FMAL, FMAL_CURVE, FMAL_CURVE_OPT, FMBT, FMBT_CURVE, FMBT_CURVE_OPT, FMPH, FMPH_CURVE, FMPH_CURVE_OPT, FMPS, FMPS_CURVE, FMPS_CURVE_OPT, FMT, FMT_CURVE, FMT_CURVE_OPT, JID, LCIDAL, LCIDBT, LCIDG, LCIDPH, LCIDPS, LCIDR, LCIDT, LCIDX, LCIDY, LCIDZ, NSABT, NSAPH, NSAPS, NSAT, NSDX, NSDY, NSDZ, PIDA, PIDB, PSABT, PSAPH, PSAPS, PSAT, PSDR, PSDX, PSDY, PSDZ, RAD1, RAD2, SAAL, and Type. Added new config value 102.
- designvars
- gauge - Added new data names designvar_ddval_opt, designvar_initialvalue_opt, designvar_lowerbound_opt, designvar_lowerbound_percent, designvar_movelimit_opt, designvar_upperbound_opt, and designvar_upperbound_percent.
- failures- Added new config values 235, 236 and 237. Added following new data names comp_dir, denom, dtmin, eps_dot_fld, eps_dot_ps, eps_dot_sm, eps_eff, eps_max, eps_min, eps_vol, epscal, fct_IDe1c, fct_IDg12, fct_IDg13, fct_IDps, fct_IDsm, Fct_Ratio, idel, inst, ismooth, itab, max_comp_strain, n_hard, ncs, nstep, num, ordin, pmax, pmin, pthickfail, shear, sig_max, sigp1_max, sigr, strain_ratio, tab_IDfld, temp_max, thinning, time_max, vol_strain, and volfrac.
- lines - Added new data names endcoords, endtangentangle, endtangentvector, geometrytype, length, startcoords, starttangentangle, starttangentvector, and topologytype.
- loads
- plotcontrols - Added new config value 6 and new data names marker_displayColor, numeric_format, numeric_precision show_entityid, and show_value_multiline.
- points - Added new data names geometrytype and topologytype.
- solids - Added new data names geometrytype, mappability, topologytype, and volume.
- surfaces - Added new data names area, geometrytype, and topologytype.
- General/Core
- hm_getcog - Added new optional arguments lumpedmassflag and system_id.
- hm_getmoi - Added new location_flag value 3 and added lumpedmassflag.
- *copymark– Added new optional arguments disable_fe_geom_duplicate and copy_elems_with_surf.
- *elementtype - Added support for string labels as input arguments.
- *feinputmerge - Added new options mergemode.sensors and mergemode.sections.
- *findmark - Added new function Bit9 value and new option recursive.
- *loadtype - Added support for string labels as input arguments.
- *mergefile2 - Added new options mergemode.sensors and mergemode.sections.
- *rundesignmethod - Added new option tableperloadcase.
- *setoption/hm_getoption- Removed option domain_handle. Added new options delete_preserve_nodes, fe_geom_dupl, morph_1d_domain_method, morph_2d_domain_color, morph_3d_domain_color, morph_autofix_squashed_domains, morph_biasing_style, morph_check_neg_jacobians, morph_cluster_mode, morph_cluster_rotation, morph_cluster_stretch, morph_constraint_size, morph_constraint_size_mode, morph_edge_domain_color, morph_element_midnodes, morph_faces_color, morph_global_influence_method, morph_global_influence_solver, morph_handle_size, morph_handle_tolerance, morph_kriging_covariance, morph_kriging_drift, morph_kriging_finish, morph_kriging_global_domains, morph_kriging_local_domains, morph_kriging_mode, morph_kriging_morphvolumes, morph_kriging_nugget_option, morph_kriging_nugget_value, morph_kriging_resume, morph_kriging_start, morph_large_domain_mode, morph_large_domain_size, morph_large_domain_solve, morph_large_domain_unfold, morph_min_handle_influence, morph_min_step_size_angle, morph_min_step_size_dist, morph_morphing_system, morph_morphvolumes_color, morph_morphvolumes_connector_mode, morph_morphvolumes_connector_realize, morph_morphvolumes_edge_continuity_adjust, morph_morphvolumes_edge_continuity_morph, morph_morphvolumes_edge_method, morph_morphvolumes_edge_points, morph_morphvolumes_mode, morph_morphvolumes_skin_only, morph_morphvolumes_tolerance, morph_morphvolumes_transparency, morph_multithread, morph_other_domain_color, morph_partitioning_add_geometry, morph_partitioning_curve_tolerance, morph_partitioning_domain_angle, morph_partitioning_inside_3d, morph_partitioning_method_quads, morph_partitioning_method_trias, morph_partitioning_order, morph_partitioning_use_geometry, morph_quality_color_plotting, morph_quality_limit, morph_quality_mode, morph_remeshing_edge_mode, morph_remeshing_element_size, morph_remeshing_interval, morph_remeshing_mesh_type, morph_remeshing_mode, morph_remeshing_preserved_shapes, morph_remeshing_qa_fail_pct, morph_remeshing_remesh, morph_remeshing_remesh_3D, morph_remeshing_size_control, morph_remeshing_size_mode, morph_remeshing_skew_control, morph_remeshing_style, morph_remeshing_zone, morph_results_component, morph_results_datatype, morph_results_datatype_values, morph_results_info_titles, morph_results_max_option, morph_results_max_value, morph_results_mesh_color, morph_results_min_max_titles, morph_results_min_option, morph_results_min_value, morph_results_mode, morph_results_plot, morph_results_plot_style, morph_results_refresh, morph_results_simulation, morph_results_simulation_values, morph_results_solve, morph_results_solver_type, morph_results_stamping_direction_x, morph_results_stamping_direction_y, morph_results_stamping_direction_z, morph_save_morphs, morph_show_domain_icons, morph_small_domain_mode, morph_small_domain_properties, morph_small_domain_size, morph_small_domain_solve, morph_small_domain_solver, morph_smoothing_iterations, morph_smoothing_mode, morph_smoothing_type, morph_symmetry_color, morph_symmetry_size, morph_use_constraints, morph_use_symmetry_links, pdm_check_latest_partrev, pdm_check_latest_partrev_interval, rdata_memory_clean, rq_numeric_format, rq_print_header, sketcher_show_construction_of_arcs, and sketcher_show_variables_in_dims.
- Meshing
- *beamsectioncreatefromentities - Added new option vertexangle.
- *beamsectioncreatefromsectioncut - Added new option vertexangle.
- *update1delements - Added new option vertexangle.
- Postprocessing
- hm_getactiveplotcontrolid - Added support for new plot_type marker.
- hm_getactiveplotcontrolvalues - Added support for new plot_type marker.
Deprecated Commands
- General/Core
- hm_ce_getediabsorbedmassgrplist
- hm_getincludeentities
- *systemconvertnodetoaxis – Use *setvalue to set the definitioncode data name on a system entity.
- Post-processing
- *animatelinear
- *animatemodal
- *animatetransient/
Removed Commands
The following commands/options have been removed and are no longer available for use in scripts:
- Data Names
- masses
- General/Core
- hm_getmass - Removed the values 7 and 8 from mass_type option.
- *feabsorbtomassentity
- *isolateelementswithinradius - Use hm_getnearbyentities and *isolateonlyentitybymark instead.
- *reconcilemasslocation
- *resolvemasslocation
- *setoption/hm_getoption- Removed the option domain_handle. Use morph_show_domain_icons instead.
- HMASCII
- *masses()
- Template Commands
- *masses()
