elementbehaviors
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- BOXID
- The box ID.
- CID
- The coordinate system ID for transforming the box referenced by BOXID.
- color
- The 1-64 color of the entity.
- config
- The configuration of the entity.
- color_rgb
- The RGB color of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- EID_BEAM
- The element ID identifying elements that are considered for deletion.
- EID_SHELL
- EID_SOLID
- EID_THICK_SHELL
- id
- The ID of the entity.
- IDGRP
- The group ID.
- include
- The ID of the include file the entity is organized in.
- includeid
- INOUT
- The flag pertaining to BOXID.
- internalid
- internalname
- The internal name of the entity.
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- NIPF
- The number of integration points within one layer that need to fail to indicate a failed layer.
- NUMFIP
- The number of layers which must fail prior to element deletion.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- PERCENT
- The deletion percentage.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- SID_BEAM
- The element set ID identifying elements that are considered for deletion.
- SID_ELEMS_SHELL
- The element ID.
- SID_ELEMS_TSHELL
- The element ID.
- SID_PART
- The part ID.
- SID_PART_SETS
- The part set ID.
- SID_SETS_SHELL
- The element set ID.
- SID_SETS_TSHELL
- SID_SHELL
- SID_SOLID
- SID_THICK_SHELL
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- STYP_OPT1
- The type of SID.
- STYP_OPT2
- The type of SID.
- TIME
- The deletion time for elimination of the element or element set.
Version History
2022.2
