*setoption
Sets various option values.
*setoption <option>=<value>
HyperMesh Tcl Modify Command
- <option>=<value>
- The name of the option and the corresponding value to assign. Valid options and values
are as follows:
- 1d_at_centroid=<value>
- Controls whether the 3D representation of 1D elements is relative to the centroid or the shear center. Valid values are:
- alt_lmb_rmb_binding=<value>
- Select action for Alt key and left + right mouse button drag.
- alt_mmb_binding=<value>
- Select action for Alt key and middle mouse button drag.
- alt_rmb_binding=<value>
- Select action for Alt key and right mouse button drag.
- anti_alisasing=<value>
- Sets the anti-aliasing mode:
- auto_bs_thickness =<value>
- Enables automatic calculation of the default thickness of shell beamsection.
- auto_cleanuptol=<value>
- Sets the geometry cleanup calculation mode. Valid values are:
- auto_elementsize=<value>
- Sets the element size calculation mode. Valid values are:
- auto_nodetol=<value>
- Sets the node tolerance calculation mode. Valid values are:
- auto_mesh_color_mode=<value>
- Sets the auto mesh color mode for mesh lines. Valid values are:
- axis_drawn_view_cube=<value>
- Control axis arrows when show_view_cube=1 or show_view_cube=2. Valid values are:
- beam_lod_threshold=<value>
- The zoom level required to make beams visible, as an integer value from 0-10 (default 6.5). 0 means mesh lines are always visible. Smaller values indicate minimal zoom is needed. Higher values mean more zoom is needed.
- 0 - Off/disabled
- beam_mesh_vis=<value>
- The visualization of mesh lines on beams.
- bitmap_animation=<value>
- The bitmap animation graphics mode. Valid values are:
- block_error_messages=<value>
- Controls the display of error messages.
- block_messages=<value>
- Controls the display of info messages.
- block_redraw=<value>
- Controls the graphics redraw. When the redraw operation is blocked, HyperMesh will not redraw unless the size of its window changes or it is de-iconified or maximized. When the redraw operation is unblocked, HyperMesh returns to normal.
- blue_auto_color_range_max=<value>
- The maximum value of the blue color range for auto coloring. Valid values are 0-255 (default 200).
- blue_auto_color_range_min=<value>
- The minimum value of the blue color range for auto coloring. Valid values are 0-255 (default 40).
- br_autofit_graphics=<value>
- Automatically fit selected entity in graphics upon isolating from browsers.
- br_autoscroll=<value>
- Automatically scroll browser list to selected entity upon selecting entity in graphics.
- br_autosort=<value>
- Automatically sort the entities with applied sorting upon creating and editing entities.
- br_filter_mode=<value>
- Automatically filter the entities with the applied filter upon creating and editing entities.
- br_filter_nested=<value>
- Show nested entities when a parent entity passes for the applied filter.
- br_partbrowser_show_components=<value>
- Show components in the Part browser hierarchy view.
- br_show_entities_all=<value>
- Show entities under subfolders in hierarchical browsers (Model, Subsystem).
- br_show_treelines =<value>
- Show tree lines in hierarchical browsers.
- bs_thickness=<value>
- The user-defined default thickness of shell beamsection.
- buffer_command_file=<value>
- Controls the command file buffering state.
- CAD_topology_revision_auto_remesh_layers=<value>
- Number of layers around operation areas to be remeshed. A value of -1 indicates that entire affected surface will be remeshed.
- CAD_topology_revision_edit_at_fe_mode=<value>
- Avoid remesh when geometry topology matches with 2D mesh edges after revision. Applicable only for remesh mode.
- CAD_topology_revision_mesh_mode=<value>
- The remesh setting for topology revision.
- CAD_topology_revision_remesh_tetra_mesh =<value>
- 3D tetra remesh mode. Applicable only for remesh mode.
- CAD_topology_revision_transform_mode=<value>
- Option to control 2D remesh on transformation of geometry. Applicable only for remesh mode.
- CAD_topology_revision_transform_mode_rule=<value>
- Option to move mesh along geometry during geometry transformation. Applicable only for remesh mode and transformation mode.
- cadupdate_inspire_installation=<value>
- The Inspire installation path for CAD update operation.
- cadupdate_parameter_immediate=<value>
- 0 - When changing parameters associated to external CAD files, do not update the parameters back in the CAD system automatically
- cleanup_tolerance=<value>
- The geometry cleanup tolerance used for geometry creation and editing operations.
- clip_boundary_elements=<value>
- The boundary element display mode for hidden line, section cut and spherical clipping.
- ctrl_lmb_rmb_binding=<value>
- Select action for Ctrl key and left + right mouse button drag.
- ctrl_mmb_binding=<value>
- Select action for Ctrl key and middle mouse button drag.
- ctrl_rmb_binding=<value>
- Select action for Ctrl key and right mouse button drag.
- coincident_picking=<value>
- The state of coincident graphical picking.
- command_file_state=<value>
- The state of writing to the command file.
- constraints_handle=<value>
- Controls the display of DOF and weights label. Valid values are:
- constraints_node_limit=<value>
- contact_surface_peak_factor=<value>
- The factor for scaling the contact surface graphical height.
- contact_surface_percent=<value>
- The percent of the element size to use for scaling the contact surface graphical length and width.
- contour_type=<value>
- The result color mode.
- create_fe_topo_upon_element_copy=<value>
- Option to create FE Topology for duplicated elements upon element copy.
- delete_assemblies_children=<value>
- Delete associated assemblies when deleting assemblies.
- delete_attachments_realization=<value>
- Delete associated FE realization when deleting attachments.
- delete_connectors_realised_fe=<value>
- Delete associated FE realization when deleting connectors.
- delete_discrete_topology_mode=<value>
- Select a remeshing method for revising modified discrete topology.
- delete_elements_mode=<value>
- delete_line_with_elements=<value>
- Delete associated 1D elements to FE Geometry line while line deletion.
- delete_part_contents=<value>
- Delete associated part content when deleting parts.
- delete_preserve_nodes=<value>
- Delete preserve nodes when deleting selected nodes.
- delete_solids_with_elements=<value>
- Delete associated elements when deleting solids.
- delete_solids_with_surface=<value>
- Delete associated surfaces when deleting solids.
- delete_surface_with_elements=<value>
- Delete associated elements when deleting surfaces.
- delete_surface_with_solids=<value>
- Delete associated solids when deleting surfaces.
- delete_subsystem_contents=<value>
- Delete subsystem content when deleting subsystems.
- detailed_elements=<value>
- The 3D visualization mode for 1D/2D elements.
- detailed_elements_beamvis=<value>
- The 3D visualization mode for 1D elements.
- detailed_elements_shellvis=<value>
- The 3D visualization mode for 2D elements.
- display_associated_geometry_fe=<value>
- Display associated geometry and FE on show, hide, and isolate.
- display_color-<item>=<value>
- The color for various objects. Valid values are 1-64. A value of 0 indicates to set the color of that object to the background color value.
- display_import_errors=<value>
- Defines whether the import process errors/warnings are displayed in a Tcl window in HyperMesh.
- duplicate_ids=<value>
- Defines whether duplicate entity IDs are allowed for supported solvers.
- dynamic_center_of_rotation=<value>
- Dynamic center during model rotation. values are 1 or 0.
- edge_lod_threshold=<value>
- The zoom level required to make geometry lines visible, as an integer value from 0-10. 0 means geometry lines are always visible. Smaller values indicate minimal zoom is needed. Higher values mean more zoom is needed.
- edge_lod_width_auto=<value>
- Defines whether to enable edge LOD auto mode.
- elem_sphere_radius=<value>
- Controls the radius of 1D element sphere visualization (default 1.0).
- element_color_mode=<value>
- The element color mode value:
- element_connectivity=<value>
- Select how newly created elements and any adjacent existing elements are connected.
- element_handle=<value>
- The display of element handles.
- element_internal_edges_mode=<value>
- The element internal edges visualization mode. This only applies to the two wireframe modes supported by *setdisplayattributes/*setmarkdisplayattributes.
- element_order=<value>
- The order of newly created elements.
- element_organization=<value>
- Select in which component the newly created elements are placed.
- element_size=<value>
- The default element size to use when calculating element densities in the auto-meshing module.
- element_window_selection_mode=<value>
- all - All nodes of an element must be inside the window to be selected
- entity_highlighting=<value>
- The mode for pre-highlighting selected entities.
- equation_handle=<value>
- The display of equation handles.
- exponential_display=<value>
- The display of floating-point numbers in the menu as standard or exponential.
- feature_angle=<value>
- The feature angle used for mesh creation and editing operations.
- fe_display=<value>
- 0 - Turns off FE display without changing the state of components.
- fe_geom_dupl=<value>
- Option to duplicate FE geometry when copying associated mesh. Valid values are 1 and 0. If the option is enabled, FE geometry is created when copying associated mesh or else orphan mesh is created. Orphan mesh is always created for orphan mesh and FE geometry is always created for FE geometry.
- feoutput_time_info=<value>
- Generates a text file containing export time info for FE entities. The file is written to the same directory as the exported file, with the name <export_file_name>_timing.txt.
- fixed_point_handle=<value>
- The display of fixed point handles.
- force_text_black=<value>
- The display of graphical text between black and white. By default, text in HyperMesh is displayed in white. However white text is not always legible, especially when users change the background color to a lighter color.
- front_face_orientation_view_cube=<value>
- The view cube front face orientation:
- g_ce_aspect_ratio_option=<value>
- Fail hexa seam or area connectors based on aspect ratio check.
- g_ce_aspect_ratio_value=<value>
- The minimum aspect ratio value to fail hexas.
- g_ce_autocreate_attachments=<value>
- Auto-create attachments during bolt connector realization.
- g_ce_autocreate_parts=<value>
- Create parts during automatic organization of realized connector entities.
- g_ce_auto_load_control=<value>
- Automatically load a connector control file.
- g_ce_bl_connection_angle=<value>
- The maximum angle allowed between two shells for a B connection.
- g_ce_boltcylinderdisplaystatus=<value>
- Show cylinder bolts.
- g_ce_boltcylinderdisplaytransparency=<value>
- The level of transparency for cylinder bolts.
- g_ce_colorby=<value>
- Defines the connector color scheme.
- g_ce_consider_custom_metadata_mapping=<value>
- Consider custom metadata mapping file during connector creation using geometry extraction.
- g_ce_consider_link_for_review=<value>
- Perform SHII operations on link entities.
- g_ce_considerboltcolinearity=<value>
- Perform collinearity check during bolt connector realization.
- g_ce_control_config=<value>
- Use a connector control config to identify redundant connector control entities.
- g_ce_control_file_path=<value>
- The connector control file path name.
- g_ce_control_id=<value>
- Use the connector control ID to identify redundant connector control entities.
- g_ce_control_keep=<value>
- The method of handling redundant connector control entities. Valid values are:
- g_ce_control_name=<value>
- Use the connector control name to identify redundant connector control entities.
- g_ce_custom_metadata_file_path=<value>
- Absolute file path to the metadata mapping file containing connector metadata name mapped to CAD metadata name.
- g_ce_Cwelddisplaystatus=<value>
- Show a graphical representation of the CWELD definition.
- g_ce_elem_org_comp_id=<value>
- The component ID for the organization of realized connector entities.
- g_ce_elem_org_option=<value>
- The organize options for realized connector entities. Valid values are:
- g_ce_equia_skew_option=<value>
- Fail hexa seam or area connectors based on equia skew check.
- g_ce_equia_skew_value=<value>
- The minimum equia skew value to fail hexas.
- g_ce_jacobian_option=<value>
- Fail hexa seam or area connectors based on equia jacobian check.
- g_ce_jacobian_value=<value>
- The maximum jacobian value to fail hexas.
- g_ce_line_vertex_angle=<value>
- The line vertex angle for significant points.
- g_ce_linked_connector=<value>
- Consider connector/attachment during connector/attachment link SHII operations.
- g_ce_linked_entity=<value>
- Consider link entities during connector/attachment SHII operations.
- g_ce_long_weld_length=<value>
- The upper bound tolerance allowed by the weld length.
- g_ce_lt_connection_angle=<value>
- The minimum angle allowed between two shells for a T connection.
- g_ce_realization_connector=<value>
- Consider realized FE entities during connector/attachment SHII operations.
- g_ce_realization_link=<value>
- Consider realized FE entities during connector/attachment Link SHII operations.
- g_ce_se_auto_register=<value>
- Automatically register shared connector entities during connector realization, feabsorb, and import.
- g_ce_se_cleanup_delete=<value>
- Clean-up shared connector entities during deletion.
- g_ce_se_cleanup_unrealize=<value>
- Clean-up shared connector entities during unrealization.
- g_ce_shell_thickness_off_for_solids=<value>
- Use linked FE attributes when positioning realized solids.
- g_ce_short_weld_length=<value>
- The lower bound tolerance allowed by weld length.
- g_ce_size=<value>
- The connector display size in model units.
- g_ce_subsystem_org_option=<value>
- Organize connector realization entities into subsystems. Valid values are:
- g_ce_warpage_option=<value>
- Fail hexa seam or area connectors based on warpage check.
- g_ce_warpage_value=<value>
- The minimum warpage value to fail hexas.
- g_ce_weld_database_file_path=<value>
- The path to a local weld database file which specifies the details of the welds.
- geom_display=<value>
- 0 - Turns off geometry display without changing the state of components.
- geom_feature_angle=<value>
- The geometry feature angle used for geometry creation and editing operations.
- geom_point_size=<value>
- Sets the size of the geometry points, between 1 and 10 (default 4).
- geom_refine_level=<value>
- The refinement level for geometry graphical faceting. Valid values are 1-5 and 11 (which indicates auto refinement). Each level increases the refinement, but also uses more memory and takes more time to compute.
- geom_stitching=<value>
- The automatic stitching mode when creating surfaces. This applies to all surface creation commands.
- geometry_parasolid_boolean=<value>
- 0 - Boolean operations will use the legacy AFC (default)
- geometry_parasolid_removefillets =<value>
- 0 – Fillet removal operations use the legacy AFC (default)
- geometry_style_view_cube=<value>
- Geometry of the view cube.
- graph_enable=<value>
- The visibility of plot entities in graphics.
- graphics_file_blank_background=<value>
- The graphics file image background color mode.
- graphics_optimize_view_ctrl=<value>
- 0 - Do not remove graphical annotations and entities when you rotate, zoom (via the mouse wheel), or pan the model.
- graphics_simplification_component=<value>
- The graphics simplification component.
- graphics_simplification_mode={<mode> <style>}
- The graphics simplification mode. This produces smoother animation when rotating or panning a model by refraining from calculating and rendering some model elements until the model manipulation stops.
- green_auto_color_range_max=<value>
- The maximum value of the green color range for auto coloring. Valid values are 0-255 (default 200).
- green_auto_color_range_min=<value>
- The minimum value of the green color range for auto coloring. Valid values are 0-255 (default 40).
- highlight-<option>=<value>
- Sets various highlight options. The option modifier is
required and specifies a specific highlight type.
- edge_thickness - The thickness of feature edge highlight (default 2.0).
- face_alpha - A value between 0 and 1 (default 0.5)
- face_color - The RGB highlight face color (default #FEB317) .
- onoff - The transparent highlight, 0 (off, default) or 1 (on).
- history_memory_limit=<value>
- The amount of memory to allow for undo-redo.
- hv_launch_flag=<value>
- Controls the launching of HyperView after an H3D creation.
- intell_max_name=<value>
- Maximum number of suggestions to be shown for name in IntelliSearch.
- intell_max_id=<value>
- Maximum number of suggestions to be shown for ID in IntelliSearch.
- intell_exact_match=<value>
- Match exact phrase while searching for names in IntelliSearch.
- last_simulation_current=<value>
- Set the last simulation step as current after loading the results.
- left_justify_num_fields=<value>
- Left justify numeric values in Entity Editor.
- legend_allow_background_transparency=<value>
- 0 - Do not allow
- legend_beyond_threshold=<value>
- The visualization for elements beyond the legend threshold.
- legend_colormap_divergent=<value>
- 0 - Disable legend divergent colormap style (use rainbow style)
- legend_ranged_discrete_button=<value>
- Controls the legend double button.
- lighting_mode=<value>
- The lighting mode.
- line_handle=<value>
- The display of line handles.
- lmb_rmb_binding=<value>
- Select action for left + right mouse button drag.
- load_base_size=<value>
- Change the base size of loads.
- load_handle=<value>
- The display of load handles.
- load_label-<config>=<value>
- The display of load labels.
- load_label_color=<value>
- The load label color. Valid values are 1-64. A value of 0 indicates to set the color to the background color value.
- load_max_size=<value>
- Change the maximum size of loads.
- load_min_size=<value>
- Change the minimum size of loads.
- load_new_scaling=<value>
- Set new scaling options
- load_scale_type=<value>
- Set scale type fixed or limits on load entities.
- load_size_magnitude-<config>=<value>
- The load display percentage when load_size_type is 1.
- load_size_type-<config>=<value>
- 0 - Uniform display
- load_size_uniform-<config>=<value>
- The load display size in model units when load_size_type is 0.
- load_solver_label=<value>
- The label type for elements and loads.
- load_visual_vector=<value>
- The location of the vector in relation to the attachment location.
- locate_view_cube=<value>
- The position of the view cube when show_view_cube=1 or show_view_cube=2. Valid values are:
- lod_threshold=<value>
- The zoom level required to make element handles visible, as an integer value from 0-10. 0 means element handles are always visible. Smaller values indicate minimal zoom is needed. Higher values mean more zoom is needed.
- mb_ask_delete_table_on_exit=<value>
- Prompt the user to delete existing Matrix Browser tables upon closing Matrix Browser.
- mb_color=<value>
- The highlight color of the entity column in Matrix Browser. Valid values are 1-64.
- mb_csv_separator=<value>
- The separator character used in the CSV file exported from Matrix Browser.
- mb_display_expression=<value>
- Show the expressions instead of values in Matrix Browser.
- mb_numeric_format=<value>
- The numeric format of result values queried in Matrix Browser.
- mb_numeric_precision=<value>
- An integer to define the number of decimal places in result values queried in Matrix Browser.
- mb_query_id_order=<value>
- The order of the queried entity IDs returned in the entity column in Matrix Browser.
- mb_show_subcase_simulation_in_col_header=<value>
- Include the subcase and simulation name in the result column label in Matrix Browser.
- mb_update_hm_on_table_cell_edit=<value>
- Automatic update of HyperMesh database upon editing queried data name values in Matrix Browserr.
- mb_userdir_path=<value>
- The Matrix Browser user directory path.
- mb_visible_rows=<value>
- The number of rows initially visible in the Matrix Browser table.
- mesh_line_color=<value>
- The mesh line color. Valid values are 1-64.
- mesh_lod_threshold=<value>
- The zoom level required to make element mesh lines visible, as an integer value from 0-10 (default 6.5). 0 means mesh lines are always visible. Smaller values indicate minimal zoom is needed. Higher values mean more zoom is needed.
- mesh_transparency=<value>
- The mesh transparency as a double value from 0-10. 0 means no transparency. Smaller values indicate minimal transparency. Higher values mean more transparency.
- method_xml_file=<value>
- The user defined StressToolMethodDefinition.xml file path to access the user defined design methods.
- mixed_property_warning=<value>
- The state of the mixed direct/indirect property assignment warning dialog.
- mmb_binding=<value>
- Select action for middle mouse button drag.
- morph_1d_domain_method=<value>
- The method used to determine the relationship between 1D domains and their surrounding domains. Valid values are:
- morph_2d_domain_color=<value>
- The color used for all 2D domains. Valid values are 1-64.
- morph_3d_domain_color=<value>
- The color used for all 3D domains. Valid values are 1-64.
- morph_autofix_squashed_domains=<value>
- Automatically invoke the large domain solver to unfold small domains which became folded during morphing. Valid values are:
- morph_biasing_style=<value>
- The style of biasing exerted by handles over their nodes. Valid values are:
- morph_check_neg_jacobians=<value>
- Check for negative Jacobians after each morph. Valid values are 0 and 1.
- morph_cluster_mode=<value>
- The method for morphing connectors, clusters (1D domains and morphconstraints), and equations. Valid values are:
- morph_cluster_rotation=<value>
- The type of rotation to apply to connectors, clusters (1D domains and morphconstraints), and equations during morphing. Valid values are:
- morph_cluster_stretch=<value>
- Use the large domain solver to smooth over distortions in the mesh around clusters during morphing. Valid values are 0 and 1.
- morph_color-<option>=<value>
- Sets various morph color options. The option modifier is
required and specifies a specific morph color object.
- domain - The domain RGB color.
- face - The face RGB color.
- symmetry - The symmetry RGB color.
- volume - The morph volume RGB color.
- morph_constraint_size=<value>
- The display size of morphing constraints in model units or screen units.
- morph_constraint_size_mode=<value>
- The type of units used for morph constraint size. Valid values are:
- morph_edge_domain_color=<value>
- The color used for all edge domains. Valid values are 1-64.
- morph_element_midnodes=<value>
- The method for adjusting element midnodes during morphing.
- morph_faces_color=<value>
- The color used for shell elements created on 3D domains. Valid values are 1-64.
- morph_global_influence_method=<value>
- Defines how global handles and morphvolumes influence nodes.
- morph_global_influence_solver=<value>
- The solver used for global domains.
- morph_handle_size=<value>
- The display size of morphing handles in model units.
- morph_handle_tolerance=<value>
- The tolerance factor used for symmetry linking, for example. Must be less than morph_handle_size/10.
- morph_kriging_covariance=<value>
- The covariance value used for Kriging algorithm. Valid values are:
- morph_kriging_drift=<value>
- The drift value used for Kriging algorithm. Valid values are:
- morph_kriging_finish=<value>
- Returns true if manual Kriging can be finished. Set to true to finish any manual Kriging that has been applied since starting.
- morph_kriging_global_domains=<value>
- Apply Kriging to all global domains. Valid values are 0 and 1.
- morph_kriging_local_domains=<value>
- Apply Kriging to all local domains. Valid values are 0 and 1.
- morph_kriging_mode=<value>
- Defines when the Kriging solver runs. Valid values are:
- morph_kriging_morphvolumes=<value>
- Apply Kriging to all morph volumes. Valid values are 0 and 1.
- morph_kriging_nugget_option=<value>
- Use nugget value during Kriging. Valid values are 0 and 1.
- morph_kriging_nugget_value=<value>
- The nugget value used for Kriging.
- morph_kriging_resume=<value>
- Returns true if manual Kriging can be resumed. Set to true to resume any manual Kriging that has been finished.
- morph_kriging_start=<value>
- Returns true if manual Kriging can be started. Set to true to start manual Kriging.
- morph_large_domain_mode=<value>
- Defines when the large domain solver runs. Valid values are:
- morph_large_domain_size=<value>
- The smallest number of elements in a domain for it to be considered a large domain.
- morph_large_domain_solve=<value>
- Always returns true. Set to true to solve large domains when in manual mode.
- morph_large_domain_unfold=<value>
- Defines whether the large domain solver runs when the mesh gets folded. Valid values are:
- morph_min_handle_influence=<value>
- The minimum value of influence between handles and nodes. Valid values are between 0 and 1.
- morph_min_step_size_angle=<value>
- The step size (in degrees) used for angle changes when rotating manipulators.
- morph_min_step_size_dist=<value>
- The step size (in model units) used for distance changes when dragging manipulators.
- morph_morphing_system=<value>
- The ID of system used for morphing. Use 0 for the global system.
- morph_morphvolumes_color=<value>
- The color used for all morph volumes. Valid values are 1-64.
- morph_morphvolumes_connector_mode=<value>
- Defines which connectors get registered to morphvolumes during creation and after adjustment. Valid values are:
- morph_morphvolumes_connector_realize=<value>
- The treatment of registered connectors during morphing. Valid values are:
- morph_morphvolumes_edge_continuity_adjust=<value>
- Defines whether the initial continuity between linked edges is maintained or reset during adjustment. Valid values are:
- morph_morphvolumes_edge_continuity_morph=<value>
- Defines whether the initial continuity between linked edges is maintained or reset during morphing. Valid values are:
- morph_morphvolumes_edge_method=<value>
- The method used to calculate the curvature of the morphvolume edges. Valid values are:
- morph_morphvolumes_edge_points=<value>
- The number of points used by each morph volume edge to represent curves
- morph_morphvolumes_mode=<value>
- Defines whether the entities registered to morphvolumes are morphed or only the morphvolumes are adjusted. Valid values are:
- morph_morphvolumes_skin_only=<value>
- If 1, only the nodes and the skin of registered meshes will be morphed until this option is set to 0 or morph_morphvolumes_mode is changed, at which point the interior will be morphed. Valid values are 0 and 1.
- morph_morphvolumes_tolerance=<value>
- The mapping tolerance. The accuracy increases as the tolerance decreases. Valid values are between 0 and 1.
- morph_morphvolumes_transparency=<value>
- The level of transparency to display faces of morph volumes. Valid values are:
- morph_multithread=<value>
- The preferred computation method for the morphing library. Valid values are:
- morph_other_domain_color=<value>
- The color used for all general, 1D, and global domains. Valid values are 1-64.
- morph_partitioning_add_geometry=<value>
- Merge partitioned domains and those created from geometry (where applicable). Valid values are 0 and 1.
- morph_partitioning_curve_tolerance=<value>
- The tolerance value (in degrees) for curvature changes which determine partition lines.
- morph_partitioning_domain_angle=<value>
- The break angle (in degrees) for determining partition lines.
- morph_partitioning_inside_3d=<value>
- Enables the partition faces inside solid meshes. Valid values are 0 and 1.
- morph_partitioning_method_quads=<value>
- The method used to partition predominantly quad meshes. Valid values are:
- morph_partitioning_method_trias=<value>
- The method used to partition predominantly tria meshes. Valid values are:
- morph_partitioning_order=<value>
- The order of partitioning.
- morph_partitioning_use_geometry=<value>
- Enables partitioning along surface edges of associated geometry. Valid values are 0 and 1.
- morph_quality_color_plotting=<value>
- 0 - Plot element quality as pass or fail
- morph_quality_limit=<value>
- The threshold value for element quality.
- morph_quality_mode=<value>
- The element quality check to be displayed after each morph. Valid values are Off, Max. 1D Length, Min. 1D Length, 2D Warpage, 2D Skew, 2D Aspect Ratio, Max. 2D Length, Min. 2D Length, 2D Jacobian, 2D Chordal Deviation, Max. 2D Quad Angle, Min. 2D Quad Angle, Max. 2D Tria Angle, Min. 2D Tria Angle, 2D Equia Skew, 2D Squish, 2D Taper, 3D Warpage, 3D Aspect Ratio, Tetra Aspect Ratio, 3D skew, 3D Volumetric Skew, Max. 3D Length, Min. 3D Length, 3D Jacobian, Tetra Collapse, Max. 3D Quad Angle, Min. 3D Quad Angle, Max. 3D Tria Angle, Min. 3D Tria Angle, 3D Squish, 3D Equia Skew, 3D Orthogonality, 3D Size Ratio, Time Step, and Quality Index.
- morph_remeshing_edge_mode=<value>
- Defines whether to keep the nodes along edges or remesh them to a new distribution. Valid values are:
- morph_remeshing_element_size=<value>
- The preferred element size when remeshing.
- morph_remeshing_interval=<value>
- Defines whether to remesh all morphed elements since the last remesh or just those for the most recent morph. Valid values are:
- morph_remeshing_mesh_type=<value>
- The mesh type for remeshing. Valid values are:
- morph_remeshing_mode=<value>
- Defines when remeshing after morphing occurs. Valid values are:
- morph_remeshing_preserved_shapes=<value>
- Enables conversion of handle-based shapes in remeshed area to node-based shapes. Valid values are 0 and 1.
- morph_remeshing_qa_fail_pct=<value>
- The threshold at which the percentage of elements failing the quality check triggers a remesh. Valid values are between 0 and 100.
- morph_remeshing_remesh=<value>
- Returns true if remeshing can be performed. Set to true to manually remesh.
- morph_remeshing_remesh_3D=<value>
- Enable remeshing 3D domains as tetras and pyramids. Valid values are 0 and 1.
- morph_remeshing_size_control=<value>
- Enabled bias toward similar element size during remeshing. Valid values are 0 and 1.
- morph_remeshing_size_mode=<value>
- The mode for target size. Valid values are:
- morph_remeshing_skew_control=<value>
- Enables bias toward minimizing skew during remeshing. Valid values are 0 and 1.
- morph_remeshing_style=<value>
- Defines whether the morphed mesh is remeshed or rebuilt. Valid values are:
- morph_remeshing_zone=<value>
- Defines how much of the morphed mesh to remesh. Valid values are:
- morph_results_component=<value>
- The component to be plotted. Valid values are:
- morph_results_datatype=<value>
- The FEA results datatype to be displayed during results plotting. The string must match one of the datatypes available in the results file.
- morph_results_datatype_values=<value>
- Return all available datatypes in the results file.
- morph_results_info_titles=<value>
- Display the information title during results plotting. Valid values are 0 and 1.
- morph_results_max_option=<value>
- Defines whether the maximum plot value is calculated automatically or set manually. Valid values are:
- morph_results_max_value=<value>
- The maximum plot value.
- morph_results_mesh_color=<value>
- The color of mesh during results plotting. Valid values are 0-64.
- morph_results_min_max_titles=<value>
- Display the minimum and maximum titles during results plotting. Valid values are 0 and 1.
- morph_results_min_option=<value>
- Defines whether the minimum plot value is calculated automatically or set manually. Valid values are:
- morph_results_min_value=<value>
- The minimum plot value.
- morph_results_mode=<value>
- Defines when to display FEA results after morphing. Valid values are:
- morph_results_plot=<value>
- Always returns true. Set to true to plot the results of a previously run FE analysis.
- morph_results_plot_style=<value>
- The FEA results plotting style. Valid values are:
- morph_results_refresh=<value>
- Always returns true. Set to true to trigger HyperMorph to write out a new solver file.
- morph_results_simulation=<value>
- The FEA results simulation to display during results plotting. The string must match one of the simulations available in the results file.
- morph_results_simulation_values=<value>
- Return all available simulations in the results file.
- morph_results_solve=<value>
- Always returns true. Set to true to run FE analysis on the mesh and plot the results.
- morph_results_solver_type=<value>
- The solver used for FEA results. Valid values are:
- morph_results_stamping_direction_x=<value>
- The x component of the vector defining the stamping direction.
- morph_results_stamping_direction_y=<value>
- The y component of the vector defining the stamping direction.
- morph_results_stamping_direction_z=<value>
- The z component of the vector defining the stamping direction.
- morph_save_morphs=<value>
- Save the list of morphs along with the HyperMesh binary file. Valid values are 0 and 1.
- morph_show_domain_icons=<value>
- Show icons at the centroids of domains. Valid values are 0 and 1.
- morph_small_domain_mode=<value>
- Defines when the small domain solver runs. Valid values are:
- morph_small_domain_properties=<value>
- The properties used when running the FEA solver. Valid values are:
- morph_small_domain_size=<value>
- The number of elements at or below which a domain is considered a small domain.
- morph_small_domain_solve=<value>
- Always returns true. Set to true to solve small domains manually.
- morph_small_domain_solver=<value>
- The solver used for small domains. Valid values are:
- morph_smoothing_iterations=<value>
- The number of smoothing iterations.
- morph_smoothing_mode=<value>
- Defines when smoothing after morphing occurs. Valid values are:
- morph_smoothing_type=<value>
- The type of smoothing applied after morphing. Valid values are:
- morph_symmetry_color=<value>
- The color used for all symmetries. Valid values are 1-64.
- morph_symmetry_size=<value>
- The display size of morphing symmetries in model units.
- morph_use_constraints=<value>
- Use all active constraints when morphing. Valid values are 0 and 1.
- morph_use_symmetry_links=<value>
- Apply handle morphing to other handles linked by active symmetries. Valid values are 0 and 1.
- mouse_append_mode=<value>
- Always add to the current selection in idle mode without holding Ctrl.
- mouse_mapping=<value>
- Set current mouse controls.
- mouse_over_highlighting=<value>
- Highlight entities on mouse hover.
- nearby_output_entities=<types>
- Sets the nearby output entity types. Valid values are components, elements, equations, loads, systems and vectors.
- nearby_radius=<value>
- Sets the nearby search radius/tolerance.
- nearby_search_method=<value>
- Sets the nearby search method. Valid values are sphere and box.
- nearby_selected_operation=<value>
- Sets the nearby selection operation. Valid values are 0 (show) and 1 (isolate).
- nodelod=<value>
- 0 - Disable node level-of-detailing
- node_size=<value>
- Sets the size of the nodes, between 1 and 10 (default 6).
- node_tolerance=<value>
- The global node tolerance. Must be greater than cleanup_tolerance/100.
- num_history_steps=<value>
- The maximum number of undo-redo steps to store in memory.
- numeric_legend_force_ranged=<value>
- 0 - Discrete legend
- numeric_legend_threshold=<value>
- The threshold value for automatic switching from discrete to ranged.
- numeric_precision=<value>
- An integer to define the number of decimal places in numerical values.
- numeric_style=<value>
- The style of numerical values.
- number_remesh_layers=<value>
- Number of layers for advanced remesh.
- pdm_check_latest_partrev=<value>
- Check for the latest part revision.
- pdm_check_latest_partrev_interval=<value>
- The time interval to check for the latest part revision.
- performance_normal=<value>
- The light setting, based on the direction of element normals.
- perspective_fov=<value>
- The perspective field of view.
- perspective_view=<value>
- The state of the perspective view.
- pick_tolerance=<value>
- The picking tolerance in pixels which the cursor must be within before an entity is selected.
- ply_link_color_and_orientation=<value>
- Auto update of colors based on ply orientation.
- ply_thickness_factor=<value>
- The ply thickness scale factor for composite layer visualization. This applies for show_composite_layers values 1 and 2.
- pr_auto_preserve_connections=<value>
- 1 - Preserve the internal connections.
- pr_box_approach_node_set=<value>
- 0 - Proximity approach will be used to find the replacement nodes to update the SETS of type NODES. (default).
- pr_check_log=<value>
- 0 - Do not allow the user to provide a file path to log replacement details. (default 0)
- pr_custom_bbox_for_equivalence=<value>
- Custom tolerance for bounding box can be provided for connecting the 1D elements from incoming file to source components
- pr_delete_src_comp=<value>
- 0 - Delete existing component.
- pr_invoke_model_checker=<value>
- 0 - Do not invoke a Model Checker Browser (default).
- pr_keep_src_comp_cardimage=<value>
- 0 - Do not copy existing component card image to incoming component.
- pr_keep_src_comp_id=<value>
- 0 - Do not assign existing component ID to incoming component.
- pr_keep_src_comp_name=<value>
- 0 - Do not assign existing component Name to incoming component.
- pr_keep_src_ent_type=<value>
- 0 - Do not assign existing component element type to incoming component element type (default).
- pr_keep_src_include=<value>
- 0 - Organize incoming entities to new include.
- pr_keep_src_mat=<value>
- 0 - Do not assign existing component material to incoming component.
- pr_keep_src_prop=<value>
- 0 - Do not assign the existing component material/property to incoming component.
- pr_merge_nodes=<value>
- 0 - Do not merge the nodes present on the boundaries of incoming component (default).
- pr_prefix_basename_suffix_based_name_pairing=<value>
- Controls whether component pairing should be done using prefix-basename-suffix matching approach. Valid values are:
- pr_retain_plotel_elem_nodeIds_from_src_comp=<value>
- The node IDs of the source component can be retained if its nodes have comments.
- pr_show_component_pairing=<value>
- 0 - Do not show component pairing (default ).
- quick_topo_selection=<value>
- Controls holding the Alt key to enable quick advanced selection for faces and edges (elements) and by path (lines and nodes).
- rbody_label=<value>
- The display of rigid body labels.
- rdata_memory_clean=<value>
- Clean results memory cache after running Results Query.
- realize_loads=<value>
- Realize loads to their engineering form at the time of model load.
- red_auto_color_range_max=<value>
- The maximum value of the red color range for auto coloring. Valid values are 0-255 (default 200).
- red_auto_color_range_min=<value>
- The minimum value of the red color range for auto coloring. Valid values are 0-255 (default 40).
- reflector_show_view_cube=<value>
- The visibility of the reflector's view cube.
- retain_element_values=<value>
- Keep/delete certain element values upon mesh edit or remesh.
- retain_loads=<value>
- Keep/delete loads when associated nodes/elements are deleted.
- retain_segments=<value>
- Retain segments upon mesh change.
- reverse_zoom_direction=<value>
- Reverse scroll wheel direction.
- rmb_binding=<value>
- Select action for right mouse button drag.
- rotation_angle=<value>
- The rotation angle used by various view commands.
- rotation_center_mode=<value>
- The rotation mode.
- rotation_center_off_screen=<value>
- Defines if the rotation center is allowed to be off screen.
- rotator_show_view_cube=<value>
- The visibility of the rotator's view cube.
- rq_csv_separator=<value>
- The separator character used in the CSV file exported by Results Query tool.
- rq_export_idpool=<value>
- Include the entity ID pool information in the CSV file exported by Results Query tool.
- rq_numeric_format=<value>
- The numeric format of the result values exported by the Results Query tool.
- rq_numeric_precision=<value>
- An integer to define the number of decimal places in result values exported by Results Query tool.
- rq_omegat=<value>
- The omega*t value used by the complex filter in the Results Query tool.
- rq_poissons_ratio=<value>
- The Poisson’s ratio value used for the von Mises strain calculations in the Results Query tool.
- rq_print_header=<value>
- Controls the visibility of the header in the file exported by the Results Query tool.
- scale_color=<value>
- The color of the modeling window model scale. Valid values are 1-64.
- scale_height=<value>
- The height of the modeling window model scale. Valid values are S (for small), M (for medium) and L (for large).
- scale_position=<value>
- The position of the modeling window model scale. Valid values are bottomleft, bottom, bottomright, centerleft, center, centerright, topleft, top, topright.
- scale_width=<value>
- The width of the modeling window model scale. Valid values are S (for small), M (for medium) and L (for large).
- section_framewidth=<value>
- Sets the width of the frame for the planar section cut as a real value in the range of 0.1 to 1.0 (default 0.2).
- section_solidfill=<value>
- Defines whether solids should be kept hollow or filled when cut by planar
section cut. Valid values are:
- 0 – Hollow
- 1 – Filled
- shift_lmb_rmb_binding=<value>
- Select action for Shift key and left + right mouse button drag.
- shift_mmb_binding=<value>
- Select action for Shift key and middle mouse button drag.
- shift_rmb_binding=<value>
- Select action for Shift key and right mouse button drag.
- show_composite_layers=<value>
- The composite layers visualization mode.
- show_delete_associated_dialog=<value>
- Show delete associated dialog before deleting.
- show_global_axes=<value>
- The global axes visualization mode.
- show_line_dir=<value>
- Displays symbols indicating geometry lines parametric direction.
- show_model_title=<value>
- Show the file path of the current model in the graphics area.
- show_newly_created_entities=<value>
- If new entities are created/updated in a collector that is hidden:
- show_plots=<value>
- Show plots when loading the model.
- show_scale=<value>
- The scale visualization mode.
- show_view_cube=<value>
- The visibility of the view cube. Valid values are:
- shrink_factor=<value>
- The element shrink factor, between 0 and 1.
- shrink_mode=<value>
- The state of the element shrink mode.
- sketcher_constraint_display_size=<value>
- The size of the constraint icons in the modeling window.
- sketcher_create_nested_holes
- Realize the sketch entity as surfaces by creating nested holes for the inner closed regions in the sketch.
- sketcher_fillet_radius=<value>
- The default fillet radius for sketch geometry.
- sketcher_merge_adjacent_faces
- Realize the sketch entity as surfaces by merging the adjacent closed regions in the sketch.
- sketcher_realize_mode
- Mode with which the sketch entity can be realized.
- sketcher_shade_closed_regions=<value>
- Shade the closed regions of the sketch profile.
- sketcher_show_center_points
- Show or hide center points of circles or arcs in sketch editing mode.
- sketcher_show_constraints
- Show or hide constraints when in sketch editing mode.
- sketcher_show_construction_aides=<value>
- The visibility of the coordinate displays when creating new sketch geometry.
- sketcher_show_construction_lines=<value>
- The visibility of the automatically created construction lines in the sketcher.
- sketcher_show_construction_of_arcs=<value>
- Show the construction lines when you hover over an arc or an open ellipse.
- sketcher_show_dimensions
- Show or hide dimensions when in sketch editing mode.
- sketcher_show_grid
- Show or hide grids when in sketch editing mode.
- sketcher_show_intersection_curves=<value>
- The visibility of the intersection curves between parts and the sketch plane.
- sketcher_show_points
- Show or hide points when in sketch editing mode.
- sketcher_show_variables_in_dims=<value>
- Show the names of variables in dimensions.
- sketcher_update_in_inspire=<value>
- Enables updating variables associated to sketch by connecting to Inspire application.
- snap_circle_center=<value>
- 0 - Off
- snap_element_centroid=<value>
- 0 - Off
- snap_element_edge=<value>
- 0 - Off
- snap_element_mid_edge=<value>
- 0 - Off
- snap_feature_hole_center=<value>
- 0 - Off
- snap_global_xyz=<value>
- 0 - Off
- snap_line_end=<value>
- 0 - Off
- snap_line_line_intersect=<value>
- 0 - Off
- snap_line_middle=<value>
- 0 - Off
- snap_mesh_node=<value>
- 0 - Off
- snap_on=<value>
- 0 - Off
- snap_on_empty_space=<value>
- 0 - Off
- snap_on_tangent_extension=<value>
- 0 - Off
- snap_perp_from_line=<value>
- 0 - Off
- snap_perp_from_surf=<value>
- 0 - Off
- snap_perp_to_line=<value>
- 0 - Off
- snap_perp_to_surf=<value>
- 0 - Off
- snap_surf_center=<value>
- 0 - Off
- snap_surf_line_intersect=<value>
- 0 - Off
- snap_system_center=<value>
- 0 - Off
- snap_tangent_from_line=<value>
- 0 - Off
- snap_tangent_to_line=<value>
- 0 - Off
- solid_transparency=<value>
- The solid geometry transparency value 0-10.
- solid_edge_width=<value>
- The solid geometry edge width 1.0-10.0. 2.5 is the legacy value.
- solvermass_graphics=<value>
- The display of solver mass graphical representation on referenced nodes.
- solvermass_handle=<value>
- The display of solvermass handles.
- specular_intensity=<value>
- The specular intensity value.
- standard_view_cube=<value>
- Facet cube arrangement standard. Valid values are:
- stereo_display=<value>
- The normal (2D) or stereo (3D) display mode.
- surface_edge_width=<value>
- The solid geometry edge width 1.0-10.0. 1.0 is the legacy value.
- surface_uv_lines=<value>
- The number of uv lines to draw on surfaces for *settopologydisplaytype 3. Must be between 0 and 20.
- sync_idle_with_browser_view=<value>
- Change the idle selector to the respective browser entity type while switching between browsers.
- system_size_uniform=<value>
- The size in model units in which systems will be drawn.
- tag_display=<value>
- The graphical display mode for tag entities.
- tag_text_display_mode=<value>
- The text display mode for tag entities. Valid values are:
- thick_1d_lines=<value>
- The state of 1D element line graphical thickness.
- thick_mesh_lines=<value>
- The state of mesh line graphical thickness.
- thickness_legend_colors={<color1> <color2> ... <colorN>}
- The colors for the thickness legend. A color can be specified for each row. Valid values are 1-64.
- thickness_legend_rows=<value>
- The number of rows for the thickness legend.
- thickness_legend_values={<value1> <value2> ... <valueN>}
- The values for the thickness legend. A value can be specified for each row. Values should be specified in order.
- topoedgecolor=<value>
- The FE topology and geometry topology edge colors:
- topoedgecolorauto=<value>
- The automatic topology edge color.
- topofacecolor=<value>
- The FE topology and geometry topology face colors:
Examples
*setoption rotation_angle=10*setoption background_colors-1={100 200 100}
*setoption background_colors-2={123 0 0}Errors
# Handle error
}Version History
14.0.130
2017.1 - Added new options anti_aliasing, edge_lod_threshold, edge_lod_width_auto, lighting_mode, specular_intensity and solidedge_width.
2019 - Added new options alt_lmb_rmb_binding, alt_mmb_binding, alt_rmb_binding, auto_cleanuptol, auto_elementsize, auto_nodetol, contact_surface_peak_factor, contact_surface_percent, ctrl_lmb_rmb_binding, ctrl_mmb_binding, ctrl_rmb_binding, delete_discrete_topology_mode, dynamic_center_of_rotation, element_connectivity, fe_display, geom_display, geom_point, hide_panels_automatically, legend_beyond_threshold, lmb_rmb_binding, load_max_size, load_min_size, load_new_scaling, load_scale_type, mmb_binding, mouse_append_mode, mouse_mapping, mouse_over_highlighting, node_size, number_remesh_layers, ply_link_color_and_orientation, pr_auto_preserve_connections, pr_box_approach_node_set, pr_check_log, pr_custom_bbox_for_equivalence, pr_delete_src_comp, pr_invoke_model_checker, pr_keep_src_comp_cardimage, pr_keep_src_comp_id, pr_keep_src_comp_name, pr_keep_src_ent_type, pr_keep_src_include, pr_keep_src_mat, pr_keep_src_prop, pr_merge_nodes, pr_retain_plotel_elem_nodeIds_from_src_comp, pr_show_component_pairing, reverse_zoom_direction, rmb_binding, shift_lmb_rmb_binding, shift_mmb_binding, shift_rmb_binding, show_model_title, show_plots, solid_edge_width, surface_edge_width, topoedgecolor, topofacecolor, topofacemodetopology_edge_display_color, topology_solid_edge_display_color and topology_solid_edge_display_mode. Added new delete_elements_mode value 4.
2019.1 - Added new options beam_lod_threshold, cadupdate_parameter_immediate, element_window_selection_mode, graphics_optimize_view_ctrl, legend_allow_background_transparency, method_xml_file, numeric_legend_force_ranged, numeric_legend_threshold, snap_circle_center, snap_circle_center, snap_global_xyz, snap_line_end, snap_line_line_intersect, snap_line_middle, snap_on, snap_on_empty_space, snap_on_tangent_extension, snap_perp_from_line, snap_perp_from_surf, snap_perp_to_line, snap_perp_to_surf, snap_surf_center, snap_surf_line_intersect, snap_system_center, snap_tangent_from_line and snap_tangent_to_line.
2020 - Added new options edge_density_visible, highlight, graph_plot, legeng_ranged_discrete_button, morph_color, nearby_output_entities, nearby_radius, nearby_search_method, nearby_selected_operation, nodelod, quick_topo_selection, realize_loads, retain_element_values, show_newly_created_entities and snap_mesh_node. Added new element_color_mode values 8, 17, 18, 19, 20, 21 and 23.
2020.1 - Added new options geometry_parasolid_boolean and pr_prefix_basename_suffix_based_name_pairing.
2021 - Added new options axis_drawn_view_cube , legend_colormap_divergent, locate_view_cube, numeric_precison, numeric_style, show_view_cube and solvermass_handle.
2021.1 - Added new options geometry_style_view_cube, reflector_show_view_cube, rotator_show_view_cube, topoedgecolorauto and topofacecolorauto. Removed value 1 for topoedgecolor and topofacecolor. Added new topoedgecolor value 4 and topofacecolor value 28.
2021.2 - Added new options CAD_topology_revision_edit_at_fe_mode, CAD_topology_revision_mesh_mode, CAD_topology_revision_remesh_tetra_mesh, CAD_topology_revision_transform_mode, CAD_topology_revision_transform_mode_rule, create_fe_topo_upon_element_copy, delete_assemblies_children, delete_connectors_realised_fe, delete_part_contents, delete_solids_with_elements, delete_solids_with_surface, delete_subsystem_contents, delete_surface_with_elements, delete_surface_with_solids, front_face_orientation_view_cube=<value>, g_ce_auto_load_control, g_ce_control_config, g_ce_control_file_path, g_ce_control_id, g_ce_control_keep, g_ce_control_name, graph_enable, rbody_label, retain_segments, section_framewidth, section_solidfill, show_delete_associated_dialog, sketcher_create_nested_holes, sketcher_merge_adjacent_faces, sketcher_realize_mode, sketcher_show_center_points, sketcher_show_constraints, sketcher_show_dimensions, sketcher_show_grid, sketcher_show_points, snap_element_centroid, snap_element_edge, and sync_idle_with_browser_view. Removed option graph_plot.
2022 - Added new options CAD_topology_revision_auto_remesh_layers, constraints_handle, constraints_node_limit, delete_attachments_realization, delete_line_with_elements, mb_ask_delete_table_on_exit, mb_color, mb_csv_separator, mb_display_expression, mb_numeric_format, mb_numeric_precision, mb_query_id_order, mb_show_subcase_simulation_in_col_header, mb_update_hm_on_table_cell_edit, mb_userdir_path, mb_visible_rows, rq_csv_separator, rq_export_idpool, rq_numeric_precision, rq_omegat, rq_poissons_ratio, sketcher_constraint_display_size, sketcher_fillet_radius, sketcher_show_construction_aides, sketcher_show_construction_lines, sketcher_show_intersection_curves, snap_element_mid_edge, snap_feature_hole_center, standard_view_cube, and solvermass_graphics.
2022.1 - Added new options beam_mesh_vis, g_ce_aspect_ratio_option, g_ce_aspect_ratio_value, g_ce_autocreate_attachments, g_ce_autocreate_parts, g_ce_bl_connection_angle, g_ce_consider_custom_metadata_mapping, g_ce_consider_link_for_review, g_ce_considerboltcolinearity, g_ce_consider_custom_metadata_mapping, g_ce_custom_metadata_file_path, g_ce_elem_org_comp_id, g_ce_elem_org_option, g_ce_equia_skew_option, g_ce_equia_skew_value, g_ce_jacobian_option, g_ce_jacobian_value, g_ce_line_vertex_angle, g_ce_linked_connector, g_ce_linked_entity, g_ce_long_weld_length, g_ce_lt_connection_angle, g_ce_realization_connector, g_ce_realization_link, g_ce_se_auto_register, g_ce_se_cleanup_delete, g_ce_se_cleanup_unrealize, g_ce_shell_thickness_off_for_solids, g_ce_short_weld_length, g_ce_subsystem_org_option, g_ce_warpage_option, g_ce_warpage_value, last_simulation_current, and partbrowser_with_components.
2022.2 - Added new options auto_bs_thickness, br_autofit_graphics, br_autoscroll, br_autosort, br_filter_mode, br_filter_nested, br_partbrowser_show_components, br_show_entities_all, br_show_treelines, bs_thickness, cadupdate_inspire_installation, elem_sphere_radius, intell_exact_match, intell_max_id, intell_max_name, left_justify_num_fields, sketcher_shade_closed_regions, and sketcher_update_in_inspire. Removed the option partbrowser_with_components.
2022.3 - Removed option domain_handle. Added new options delete_preserve_nodes, fe_geom_dupl, morph_1d_domain_method, morph_2d_domain_color, morph_3d_domain_color, morph_autofix_squashed_domains, morph_biasing_style, morph_check_neg_jacobians, morph_cluster_mode, morph_cluster_rotation, morph_cluster_stretch, morph_constraint_size, morph_constraint_size_mode, morph_edge_domain_color, morph_element_midnodes, morph_faces_color, morph_global_influence_method, morph_global_influence_solver, morph_handle_size, morph_handle_tolerance, morph_kriging_covariance, morph_kriging_drift, morph_kriging_finish, morph_kriging_global_domains, morph_kriging_local_domains, morph_kriging_mode, morph_kriging_morphvolumes, morph_kriging_nugget_option, morph_kriging_nugget_value, morph_kriging_resume, morph_kriging_start, morph_large_domain_mode, morph_large_domain_size, morph_large_domain_solve, morph_large_domain_unfold, morph_min_handle_influence, morph_min_step_size_angle, morph_min_step_size_dist, morph_morphing_system, morph_morphvolumes_color, morph_morphvolumes_connector_mode, morph_morphvolumes_connector_realize, morph_morphvolumes_edge_continuity_adjust, morph_morphvolumes_edge_continuity_morph, morph_morphvolumes_edge_method, morph_morphvolumes_edge_points, morph_morphvolumes_mode, morph_morphvolumes_skin_only, morph_morphvolumes_tolerance, morph_morphvolumes_transparency, morph_multithread, morph_other_domain_color, morph_partitioning_add_geometry, morph_partitioning_curve_tolerance, morph_partitioning_domain_angle, morph_partitioning_inside_3d, morph_partitioning_method_quads, morph_partitioning_method_trias, morph_partitioning_order, morph_partitioning_use_geometry, morph_quality_color_plotting, morph_quality_limit, morph_quality_mode, morph_remeshing_edge_mode, morph_remeshing_element_size, morph_remeshing_interval, morph_remeshing_mesh_type, morph_remeshing_mode, morph_remeshing_preserved_shapes, morph_remeshing_qa_fail_pct, morph_remeshing_remesh, morph_remeshing_remesh_3D, morph_remeshing_size_control, morph_remeshing_size_mode, morph_remeshing_skew_control, morph_remeshing_style, morph_remeshing_zone, morph_results_component, morph_results_datatype, morph_results_datatype_values, morph_results_info_titles, morph_results_max_option, morph_results_max_value, morph_results_mesh_color, morph_results_min_max_titles, morph_results_min_option, morph_results_min_value, morph_results_mode, morph_results_plot, morph_results_plot_style, morph_results_refresh, morph_results_simulation, morph_results_simulation_values, morph_results_solve, morph_results_solver_type, morph_results_stamping_direction_x, morph_results_stamping_direction_y, morph_results_stamping_direction_z, morph_save_morphs, morph_show_domain_icons, morph_small_domain_mode, morph_small_domain_properties, morph_small_domain_size, morph_small_domain_solve, morph_small_domain_solver, morph_smoothing_iterations, morph_smoothing_mode, morph_smoothing_type, morph_symmetry_color, morph_symmetry_size, morph_use_constraints, morph_use_symmetry_links, pdm_check_latest_partrev, pdm_check_latest_partrev_interval, rdata_memory_clean, rq_numeric_format, rq_print_header, sketcher_show_construction_of_arcs, and sketcher_show_variables_in_dims.
2023 - Removed options background_colors-1, background_colors-2, edge_density_visible, and hide_panels_automatically. Added new options blue_auto_color_range_max, blue_auto_color_range_min, display_associated_geometry_fe, g_ce_boltcylinderdisplaystatus, g_ce_boltcylinderdisplaytransparency, g_ce_colorby, g_ce_Cwelddisplaystatus, g_ce_size, g_ce_weld_database_file_path, green_auto_color_range_max, green_auto_color_range_min, red_auto_color_range_max, and red_auto_color_range_min.
